Internet Router
bericaleb
Experts
I need to configure a new internet router to install on our perimeter network. I need help in the following:
1. the standards for internet router configurations - some tips
2. the IOS to upgrade to from System image file is "flash:c1841-ipbase-mz.124-3i.bin".
3. The router is a Cisco 1841.
Please see the following show version output for the new router.
yourname#sh ver
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(3i), RELEASE SO
FTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 28-Nov-07 18:17 by stshen
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
yourname uptime is 36 minutes
Cisco 1841 (revision 7.0) with 114688K/16384K bytes of memory.
Processor board ID FHK1233228R
2 FastEthernet interfaces
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
Your ideas will be great.
6 Replies 6
ohassairi
Level 5
Level 5
1.from the web interface (sdm) go to configure/security audit. follow instructions.
try also to put access lists on vty/snmp/http...
how do I tell the memory from this show version output.
fint1841#sh ver
FTWARE (fc2)
fint1841 uptime is 20 minutes
fint1841#
114MB+16MB = Rounded to 128MB
HTH,
__
Edison.
Or without rounding:
114688KB + 16384KB = 131072KB = 128 MB
That is is the DRAM, how about the FLASH memory?
