Internet-Switch- Security Config
ronald.ramzy
Multiple ISP are terminated on Cisco 2960 Layer2Switch. Need advice on how to secure the switch and connect to the core-network to measure the bandwdith..
(( From the switch connection goes to 3-department, I need to dedicate bandwdith to these department as well, total bandwidth is 2MB now, so need to give 1MB / 512KB / 512KB )
Marwan ALshawi
i am not sure if 2960 support policing
if yes this is your option to limit the bandwidth
for example to limit the traffic from one port to 512 k
let say all traffic from 10.1.0.0/24 subnet connected to port fa1/0
access-list 100 permit ip 10.1.0.0 0.255.255.255 any
class-map map1
match access-group 100
plicy-map policy1
class map1
police 512000 ecceed-action trasmit violate drop
interface fa0/1
service-policy policy1 input
if there is no policing try to check if there is any traffic aggregater in the switch
good luck
Many Thanks for your reply.
How could I secure the switch and what is required to connect the swtich to the network in a securely manner
actually it depends if its connected to end point or not
in gemeral
make the vtp mode trasnparant
make the managment vlan other than vlan 1
put unused port in unused vlan and shut down the ports
enable STP guard or enable portsecurity and limit the number of MAC on that port
make a complex password for login
and use policing to limit the traffic and avoid ant DOs attack
good luck
if helpful Rate
