internet working on router but not on network
mi0hoz
I'm just starting to learn about Cisco. I have managed to get my router to connect to adsl and I can ping internet and have dhcp working. The problem is, I can't access the net from my laptop. Here's my config:
Current configuration : 2659 bytes
version 12.4
hostname Home-Router
boot-start-marker
boot-end-marker
logging buffered 4096 debugging
enable secret 5 $xxxxxxxxxxxxxxxxxxxxxxxxxx.
enable password xxxxxxxxxxxxxxx
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.100.1 192.168.100.10
ip dhcp pool Home
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
interface FastEthernet0
ip address 192.168.100.1 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet1
interface FastEthernet2
shutdown
interface FastEthernet3
shutdown
interface FastEthernet4
shutdown
interface FastEthernet5
shutdown
interface FastEthernet6
shutdown
interface FastEthernet7
shutdown
interface FastEthernet8
shutdown
interface ATM0
description ADSL Connection to BTInternet
mtu 1492
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode itu-dmt
interface Vlan1
no ip address
shutdown
interface Dialer1
description $FW_OUTSIDE$
ip address negotiated
ip access-group 102 in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
encapsulation ppp
no ip mroute-cache
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap callin
ppp chap hostname bthomehub@btbroadband.com
ppp chap password 0 password
ppp pap sent-username bthomehub@btbroadband.com password 0 BT
ppp ipcp dns request
ppp ipcp mask request
ppp ipcp route default
ppp ipcp address accept
interface Dialer0
ip address dhcp
ip nat outside
encapsulation ppp
shutdown
dialer pool 1
dialer idle-timeout 0
dialer persistent
dialer-group 1
no cdp enable
ppp chap password 0 BT
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
ip http path slot1:
access-list 10 permit 192.168.100.0 0.0.0.255
access-list 101 permit ip any any
control-plane
line con 0
line aux 0
line vty 0 4
password xxxxxxxxxx
login
no scheduler allocate
end
Any help much appreciated
it looks like the only thing missing in your config is:
ip nat inside source list 10 interface Dialer1 overload
That's it! Many thanks!
