Invalid command "Crypto" on CSR1000V router
rvignz
I'm trying to update the certificate using the following commands
ip-10-0-115-39#config t
Enter configuration commands, one per line. End with CNTL/Z.
ip-10-0-115-39(config)#crypto pki enroll MY_CA
% Invalid input detected at '^' marker.
From other posts, I verified I've my image contains k9 which means it supports crypto.
share the output of #show version
Good luck
KB
