IOS 12.4-15.T1 High CPU Usage from Show Run CLI
kst.amand
I recently upgraded a 2811 to 12.4-15.T1 and since doing that, I receive High CPU usage from a "Show Run" command. This never happend in the past.
This router has 512MB DRAM, so I'm hoping there's no shortage along these lines.
Attached is the outoupt (excluding 0.00%) from sh cpu process which hopefully will give some insight - output shows Virtual Exec as the culprit.
Any ideas?
5 Replies 5
paolo bevilacqua
Any particular reason fro using 12.4(15)T1?
You will find that newer releases often have changed behavior and something plain bugs causing havoc.
We are working with GDOI/GETVPN, which started with 12.4(11)T.
We were encountering a CEF SNMP error introduced with 12.4(11)T2 which caused us to upgrade from that version.
Fortunately, the High CPU usage appears to be short lived and non-service affecting.
thomas.anthony
if you see your cpu output VTY is the one using the max cpu.check if the debug is enabled and output has been redirected to the vty(using the terminal monitor or the no logging console command), the amount of CPU
resources used by the virtual EXEC process increases
82 6008 1279 4697 90.94% 9.45% 1.00% 514 Virtual Exec
thomas.anthony
also Check for a possible security issue. Commonly, high CPU utilization is caused
by a security issue, such as a worm or virus operating in your network. Usually,
a configuration change, such as adding additional lines to your access lists can
mitigate the effects of this problem.
No debugging is currently defined, also verified with "un all".
"No logging console" issued, still getting same high cpu usage.
I have a test router on a bench, no network connectivity, so I wouldn't expect any type of security issue. I get this same high CPU usage.
Any other thoughts?
Thank you for the feedback.
