IOS 12.4-24T1 can't support IPv6 netflow?
vassiliev
Dear All:
        I have got a Cisco router 2811, IOS version is:
        c2800nm-advipservicesk9-mz.124-24.T1
       But when I need to configure IPv6 netflow, the router can't get this command:
       ipv6 flow-XXXXXXXXXXX     For Example: ipv6 flow-export xxxxxxx     ╮(╯▽╰)╭
       Did this IOS didn't support IPv6 netflow? I check the document, it said if you want use IPv6 netflow, just change the netflow version from 5 to 9 is OK.
       Is it right?!
       Thanks ~!
0 Replies 0
