04-07-2013 07:20 PM - edited 03-04-2019 07:31 PM
I need help to configure a router 1812 as failover,
I walk with fixed ip internet link in Fe0 (need to determine the mac) and a dynamic ip link in FE1, other ports with a single vlan dhcp 172.20.16.1
I managed to do DHCP, connect to internet, to make nat vlan.
But I could not do failover and load balance neither.
thanks for the help.
04-07-2013 08:03 PM
Here is simple example config
f0
ip add 1.1.1.1 255.255.255.252
ip nat outside
f1
ip add dhcp
ip nat outside
access-list 100 permit ip 172.20.16.0 0.0.0.255 //if you have other subnets on LAN you need to add ACL
ip route 0.0.0.0 0.0.0.0 1.1.1.2
ip route 0.0.0.0 0.0.0.0 f1
route-map ISP1
match ip address 100
match interface f0
route-map ISP2
match interface f1
ip nat inside source route-map ISP1 interface f0 overload
ip nat inside source route-map ISP2 interface f1 overload
Hope it will help.
Best regards,
Abzal
04-08-2013 12:01 AM
Thank you,
performed the procedures mentioned and it did not work without internet access.
04-07-2013 09:17 PM
I am not sure about the load balancing (unless i do some research myself) but for failover, I could think of using ip sla with default routes.
for eg,
ip route 0.0.0.0 0.0.0.0 int fe0 track 1
ip route 0.0.0.0 0.0.0.0 int fe1 200
The second default route (with AD 200) is a floating route which will only kick in if the other one fails.
you can confgigure the tracking based on the Primary ISP ip address pingable. Most of the times, the reachability to the ISP would be the reason for internet failure.
ip sla 1
icmp-echo
timeout 1000
threshold 2
frequency 3
ip sla schedule 1 life forever start-time now
track 1 ip sla 1 reachability
Please note that the syntax may change based on the IOS version.
Hope it helps!
Mohit
04-08-2013 12:04 AM
Thank you,
I researched and found the comados running, 'show track", monitoring the link works, however I could not share the internet.
04-08-2013 12:07 AM
Thank you,
The solution that I suggested will not do load balancing. this will only do automatic failover when primary service fails.
Mohit
04-08-2013 12:10 AM
This configuration works if unplug the f0, f1 and assumes disconnect the f1, f0 assumes.
I'm not sure I believe in this load balance, how to use in fail over?
Remembered that monitors your code above f0.
thanks for listening.
! WAN 0
interface F0
description Link Ajato
ip address dhcp
no shutdown
ip nat outside
ip virtual-reassembly
! WAN 1
interface F1
description Link Net
ip address dhcp
no shutdown
ip nat outside
! Vlan1
interface Vlan1
description LAN Interface
ip address 172.20.16.1 255.255.255.0
ip nat inside
ip tcp adjust-mss 1452
ip route 0.0.0.0 0.0.0.0 F0 track 123
access-list 110 permit ip 172.20.16.0 0.0.0.255 any
route-map fixed-nat permit 10
match ip address 110
match interface F0
route-map dhcp-nat permit 10
match interface F1
ip nat inside source route-map fixed-nat interface F0 overload
ip nat inside source route-map dhcp-nat interface F1 overload
04-08-2013 12:26 AM
Hi Anderson,
Honetly i did not understand your comments above. With the config that you have shown, it looks like that you are trying to merge Abzal's and mine config together. I dont think that would be a good idea.
And looking at his config template, I am not sure if you could have two default routes at the same time (never tried myself) unless someone would have done it in real scenario.
Mohit
04-08-2013 01:29 AM
of course you can have 2 default routes with the same AD and the IOS will do load-sharing per src-dst IP pair for transit traffic and per-packet for traffic generated by the device.
The problem with the latest config is that there is only one default route( what's the use of tracking a route if you haven't got a backup route to do the failover).
Alain
04-08-2013 01:42 AM
Alain
Well, I had suggested two default routes as per my original notes. I was expecting that there, yes otherwise there is no point of tracking the first default route.
04-11-2013 07:28 AM
Good morning friends,
Would anyone have a manual on how to use ios?
So I could take a studying and not be messing with something that staff should be simple to do.
Thank you.
