IOS 2801 QoS and VPN
Deepseadata
Hey there,
Sorry. I've been reading and reading but I guess I'm doing an uncommon scenario.
I have a slow (256k) wan link. I need to push all WAN users aside when I dial in with my VPN client to do maint.
Can anyone give me some QoS options?
The other QoS needs I have are that I have a few vLAN's but I need to give one vlan all/most of the WAN bandwidth and push aside the other vlan traffic.
Have any tricks up your sleeve?
32 Replies 32
class-map match-all crewdata
match access-group name crewdata
class-map match-all ownerdata
match access-group name ownerdata
policy-map QoS
class ownerdata
bandwidth remaining percent 99
class crewdata
bandwidth remaining percent 1
crypto ipsec transform-set ESP-3DES-SHA esp-3des esp-sha-hmac
crypto ipsec profile madsummer_Profile1
set transform-set ESP-3DES-SHA
set isakmp-profile madsummer-ike-profile-1
interface Loopback0
ip address 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
description Starboard Stratos VSAT$FW_OUTSIDE$
ip address 10.20.46.20 255.255.255.0
ip nat outside
ip virtual-reassembly
no ip mroute-cache
speed 100
full-duplex
service-policy output QoS
interface FastEthernet0/3/0
interface FastEthernet0/3/1
interface FastEthernet0/3/2
interface FastEthernet0/3/3
interface Virtual-Template1 type tunnel
ip unnumbered Loopback0
tunnel mode ipsec ipv4
tunnel protection ipsec profile madsummer_Profile1
interface Vlan1
description $FW_INSIDE$
ip address 192.168.49.1 255.255.255.0
ip nat inside
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
ip nat pool madsummer_INTERNET 10.20.46.20 10.20.46.20 netmask 255.255.255.0
ip nat inside source list 1 pool madsummer_INTERNET overload
ip access-list extended crewdata
remark match crewdata source sebnet address
permit ip 192.168.54.0 0.0.0.255 any
remark match crewdata destination subnet address
permit ip any 192.168.54.0 0.0.0.255
ip access-list extended ownerdata
permit ip 192.168.51.0 0.0.0.255 any
remark match ownerdata source subnet address
remark match ownerdata destination subnet address
permit ip any 192.168.51.0 0.0.0.255
access-list 1 permit 192.168.0.0 0.0.255.255
The LAN's that are heading for the internet are:
192.168.54.0 (crewdata)
192.168.51.0 (ownerdata)
You didn't apply the nested policy which includes the shaper. Without it, policy will only be effective when the Ethernet interface is congested (at either 10 or 100 Mbps) when we want it to manage 256 Kbps. See my prior post on what to do.
Second, didn't realise NAT was involved. This might impact policy, I don't recall order of operations. ACLs might not be seeing internal addresses, but instead see NAT addresses. This might account for lack of matches on outbound interface.
Not 100% what you do when NAT is active. I'm pretty sure we can mark outbound packets before they're NAT'ed, and then treat traffic on markings, but there might be a better method.
I'm pressed for time at the moment, won't be able to look again at this until tonight.
In the mean time, you might try just:
policy-map tmp
class class-default
shape average 225000
service-policy outbound tmp
Hey! Thanks for lookin on a Sunday.
I'll give it a try and let you know what happens.
Have a nice day, Joe.
