IOS Bundled Help
KGrev
Level 4
Level 4
I'm sure this topic has been beat to death but i'm getting forgetful in my old age. I have an ISR 809 router running an older
ir800-universalk9.SPA.158-3.m2a firmware
and want to update it. The version i'd like to use is
ir800-universalk9-bundle.SPA.159-3.m7a.bin
but it is a bundled version like the rest of the versions offered on the downloads page. When I try to set this version to boot i get an error
exec format error
How do I get around this error. Is it because of the bundled IOS?
Mark Elsen
 - Ref : https://www.cisco.com/c/en/us/td/docs/routers/IIoT/release-notes/15-9-3M7/15-9-3M7-Release-Note.html
   On the
IR8x9
devices, the
IR800 bundle
image can be copied via Trivial File Transfer Protocol (TFTP) or SCP to the IR800, and then installed using the
 bundle install flash:<image name>
command. The
IR800 <image>.bin file
can NOT be directly booted using the
boot system flash:/image_name
Detailed instructions are found in the Cisco IR800 Integrated Services Router Software Configuration Guide .
                     Please follow these  procedures ; and check the link from the previous sentence too ,
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
Mark Elsen
   On the
IR8x9
devices, the
IR800 bundle
command. The
 M.
       Beauty and terror
      Just keep going
       No feeling is final
That helped, thank you.
