IOS commands for NAT
imanco671
Hello Community,
I have been using the PDM, I want to get familiar with IOS, so I am learning right now.
My daily routines on my PIX firewall to do the following (which I want to do in command line for now on):
1. add new server's IP address (173.x.x.x.22) along with the name (server01) to my interface called (NewBlock).
2. add that server's name to the group (DemoNetworkGroup)
3. Create a new access rule allowing it to be opened for port 80 traffic.
4. Create a new Translation Rule for 173.x.x.22
See it is a little weird in my setup, I have the PIX translating WAN IP addresses to WAN IP addresses. Then these WAN IP addresses goes to another router. So if you see that I am translating WAN address to WAN address, dont think its a mistake.
My internal interface is  called NewBlock.
My outside interface is  called Outside
Thank for helping me learn!!!
John
Okay, you have most of the commands. In reference to your original post here are the commands -
1) name 173.x.x.x webserver
2) object-group network DemoNetworkGroup
   network-object host 173.x.x.x
3) ** see below
4) static (NewBlock, outside) 173.x.x.x 173.x.x.x netmask 255.255.255.255
3) all depends on your existing access-list. Presumably you have an access-list applied to the outside interface ie. something like this in your config -
access-group outside_in in interface outside  <-- where outside_in is the name of the access-list (obviously yours may be different).
The line you would need to add for port 80 access from any host on the internet would be -
access-list outside_in permit tcp any host 173.x.x.x eq www
you need to look at your acl and work out where to put the line. If your acl only has permits in it then it safe simply to type in the above line and it will simply add it to the end. There is an implicit "deny ip any any" at the end of every acl but if there is no actual explicit entry your line will come before it.
There could be a couple of other possibilities -
1) you have a "deny ip any any" line explicitly at the end of the acl
or
2) you have a deny somewhere in your acl that would block traffic to the web server so you need your line to go above it.
Either way you need to enter the above acl entry with a line index number. If you do a sh access-list outside_in you will see the line numbers. Note, you need to run the actual "sh access-list outside_in" command to see the line numbers. If you view the access-list in the running config with "sh run" you do not see the line numbers. If you then entered a new acl entry with a line number of 4 it will simply bump up the existing line numbers ie. line 4 becomes 5, 5 becomes 6 etc. Don't worry nothing gets overwritten of deleted.
So assuming you needed your new acl entry to be line 10 yo would modify the above to be -
access-list outside_in line 10 permit tcp any host 173.x.x.x eq www
Jon
14 Replies 14
Jon Marshall
John
What exactly is your question ?
Jon
SunilKhanna
Hi John,
Here is a URL which lists few NAT documents availble on cisco.com, thought you might find it useful.
http://www.cisco.com/en/US/tech/tk648/tk361/tk438/tsd_technology_support_sub-protocol_home.html
Sunil
Regards, Sunil Khanna
Hi Jon,
I just wanted to know the proper commands. I only ask for them b/c I am afraid I may mess something up if I research and try things myself. I rather be sure that I am inputting the proper commands from an expert like you.
Sorry, not trying to be lazy...
Hi Sunil,
Thanks for the link!!
John
John
No problem. I was just a bit confused that was all
Jon
Hi Jon,
Any idea on what commands I should run?
John
Oh sorry, i thought the docs has provided that.
Okay can you clarify before posting commands -
1) what version of software on pix - "sh ver" will tell you
2) not sure what you mean by -
you don't add things to interfaces like that. Could you explain exactly what you mean here ?
Presumably you already have an access-list that you want to add this new access to ? If so does it have an explicit "deny ip any any" at the end or not ? If it does you need to enter the new acl entry by index number. If it doesn't you can just add it to the access-list and it will be added at the end.
Just to confirm you are natting the IP address to the same IP address ? Which interfaces ?
Jon
Hi Jon,
No Problem,
1. Cisco PIX Firewall Version 6.3(5)
    Cisco PIX Device Manager Version 3.0(4)
Yes I am NATing the 173.x.x.x. address to interface named: NewBlock.
Here are the lines I want to show in after pulling my running-config (below is the outcome I want, which is the NATing and defining of my ip address 173.x.x.x.):
1. name 173.x.x.x webserver
2.network-object webserver 255.255.255.255
3. pdm location webserver 255.255.255.255 NewBlock
4. static (NewBlock, outside) webserver webserver netmask 255.255.255.255 0 0
I am not sure if I am missing anythig from above or not. The "pdm" statement is from using the web interface, which I am trying to stop using. I thing there should be a "access-list" line above.
John
John
3) ** see below
or
Jon
John
One other point i forgot to mention. If you are adding the server to an object-group there may well be entries in the acl that reference that object-group so you may not actually need make a new entry in your acl.
Be aware that if for example you had port 25 (smtp), 80(www), 443(ssl) allowed to this object-group this allows access to those ports on all servers in that object-group. So by adding the server to the object-group you are effectively allowing access to the above ports on the new server. Whether or not those services are running is another matter but you should only allow the ports to any server that are needed.
So sometimes you don't actually want to add it to an object-group because it allows too much access.
Just something to be aware of.
Jon
Hi John,
Great replys. Some good points!
I have issued the name command successfully
I have also issued the static command successfuly (which I beleive is to define the static NAT? )
I am not on the ACL. Is this my next step? or am I missing a command to issue before this step?
I am confused with my ACL. I just want to clarify a couple things.
I have the following questionable lines in my "show run"...
conduit permit tcp host Abbott05 eq www any
access-list inside_outbound_nat0_acl permit ip host hcwin07 any
I am consused on the above. I beleive that my in_outside is called....."inside_outbound_nat0_acl" ?
Or is my outside_in called...."inside_outbound_nat0_acl" ?
When I issue the "show access-list insode_outbound_nat0_acl" I get:
access-list inside_outbound_nat0_acl line 43 permit ip host POI any (hitcnt=7494)
But I do not see any of my normal www or smtp ACLs when I issue the command.
John
Ah yes, i seem to remember you are allowing access using conduits. Conduits were used before acls came into use on the pix.
You had better post the config (minus any public IP info) so i can have a look. It would probably be a good idea to look to migrate all the conduit commands to access-lists. Conduits really aren't much in use anymore.
Jon
Jon,
Great idea, I would like to clean up while learning command line for inserting, defining and issueing NATs on my PIX.
Could those Conduit lines be from using the PDM gui? (which I am trying to stop using)
Let me know if you see something "screwy" in my config. I'll clean up...
Below is my running config.
Result of firewall command: "show run"
: Saved
PIX Version 6.3(5)
interface ethernet0 100full
interface ethernet1 100full
interface ethernet2 auto shutdown
interface ethernet3 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
nameif ethernet2 RESCUE security55
nameif ethernet3 NewBlock security30
enable password hJswxxxtqi3ZUj1 encrypted
passwd 2KFQnbxxxdI.2KYOU encrypted
hostname AGNIPIX520
domain-name OurDomain.com
clock timezone EST -5
clock summer-time EDT recurring
fixup protocol dns maximum-length 512
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
name 69.xx.xxx.178 "xxxxx"-"xxxxx"
name 69.xx.xxx.175 "xxxxx"
name 69.xx.xxx.174 "xxxxx"
name 69.xx.xxx.170 "xxxxx"
name 69.xx.xxx.167 "xxxxx"
name 69.xx.xxx.133 "xxxxx"
name 69.xx.xxx.132 "xxxxx"
name 69.xx.xxx.131 "xxxxx"
name 69.xx.xxx.161 "xxxxx"
name 69.xx.xxx.158 "xxxxx"
name 69.xx.xxx.156 "xxxxx"
name 69.xx.xxx.150 "xxxxx"
name 69.xx.xxx.128 "xxxxx"
name 164.xxx.xx.82 "xxxxx"
name 164.xx.xxx.10 "xxxxx"
name 69.xx.xxx.136 "xxxxx"
name 209.xxx.xx.129 "xxxxx"
name 69.xx.xxx.138 "xxxxx"
name 164.xxx.xx.149 "xxxxx"
name 69.xx.xxx.183 "xxxxx"
name 164. xxx.xx..98 "xxxxx"
name 76. xxx.xx..6 "xxxxx"
name 164. xxx.xx.106 "xxxxx"
name 69.xx.xxx.141 "xxxxx"
name 138. xxx.xx..139 "xxxxx"
name 138. xxx.xx..138 "xxxxx"
name 138. xxx.xx..132 "xxxxx"
name 138. xxx.xx..131 "xxxxx"
name 69.xx.xxx.139 "xxxxx"
name 78. xxx.xx..115 "xxxxx"
name 69.xx.xxx.176 "xxxxx"
name 164. xxx.xx.101 "xxxxx"
name 199. xxx.xx..116 "xxxxx"
name 38. xxx.xx..170 "xxxxx"
name 141. xxx.xx..1 "xxxxx"
name 141. xxx.xx..22 "xxxxx"
name 141. xxx.xx..21 "xxxxx"
name 141. xxx.xx..20 "xxxxx"
name 141. xxx.xx.20 "xxxxx"
name 141.xxx.xx.1 "xxxxx"
name 69.xx.xxx.166 "xxxxx"
name 207.xx.xx..158 "xxxxx"
name 69.xx.xxx.177 "xxxxx"
name 69.xx.xxx.137 "xxxxx"
name 69.xx.xxx.185 "xxxxx"
name 69.xx.xxx.140 "xxxxx"
name 207. xxx.xx..156 "xxxxx"
name 69.xx.xxx.173 "xxxxx"
name 69.xx.xxx.172 "xxxxx"
name 173. xxx.xx..64 newblock-pool
name 69.xx.xxx.165 "xxxxx"
name 69.xx.xxx.164 "xxxxx"
name 69.xx.xxx.163 "xxxxx"
name 69.xx.xxx.162 "xxxxx"
name 69.xx.xxx.159 "xxxxx"
name 69.xx.xxx.157 "xxxxx"
name 69.xx.xxx.155 "xxxxx"
name 69.xx.xxx.154 "xxxxx"
name 69.xx.xxx.153 "xxxxx"
name 69.xx.xxx.152 "xxxxx"
name 69.xx.xxx.151 "xxxxx"
name 69.xx.xxx.149 "xxxxx"
name 69.xx.xxx.147 "xxxxx"
name 69.xx.xxx.146 "xxxxx"
name 69.xx.xxx.145 "xxxxx"
name 69.xx.xxx.144 "xxxxx"
name 69.xx.xxx.142 "xxxxx"
name 69.xx.xxx.135 "xxxxx"
name 69.xx.xxx.189 "xxxxx"
name 69.xx.xxx.182 "xxxxx"
name 69.xx.xxx.181 "xxxxx"
name 69.xx.xxx.180 "xxxxx"
name 69.xx.xxx.179 "xxxxx"
name 69.xx.xxx.171 "xxxxx"
name 69.xx.xxx.184 "xxxxx"
name 69.xx.xxx.148 "xxxxx"
name 69.xx.xxx.187 "xxxxx"
name 69.xx.xxx.169 "xxxxx"
name 69.xx.xxx.160 "xxxxx"
name 69.xx.xxx.186 "xxxxx"
name 69.xx.xxx.168 "xxxxx"
name 69.xx.xxx.188 "xxxxx"
name 173. xxx.xx..66 john
name 173.x.xx.x johntest2
name 173.x.x.x. johntest3
name 173.x.x.x. johntest4
name 173.x.x.x. NBfirewall
object-group network DemoNetworkPublicGroup
  description DemoNetworkPublicGroup
  network-object "xxxxx" 255.255.255.255
  network-object v"xxxxx" 255.255.255.255
  network-object 69.xx.xxx.190 255.255.255.255
object-group network EveryOneInsideGroup
  description EveryOneInsideGroup
  network-object "xxxxx"xxxxx"S01 255.255.255.255
  network-object "xxxxx"-DomainVPN 255.255.255.255
object-group network http_httpsGroup
  description http_httpsGroup
  network-object "xxxxx"255.255.255.255
object-group network publicpool
  description publicpool
  network-object PublicPool 255.255.255.192
object-group network "xxxxx"
  description "xxxxx"
object-group service UltraVNC tcp
  description UltraVNC
  port-object range 5800 5801
  port-object range 5900 5901
object-group service NetMeeting tcp
  description NetMeeting
  port-object range 1503 1503
  port-object range 1721 1721
  port-object range h323 h323
object-group service RDP tcp
  description RDp
  port-object range 3389 3389
object-group service VONAGE udp
  description VONAGE
  port-object range 65535 65535
  port-object range ntp ntp
  port-object range 5060 5061
  port-object range 10000 20000
object-group service CISCO_VPN tcp-udp
  description CISCO_VPN
  port-object range 10000 10000
object-group network VPNboxes
  description anything that uses IPSEC
object-group service BizConnect tcp
  port-object range 9080 9080
  port-object range 8081 8081
  port-object range 4080 4080
object-group service FTP-7700 tcp
  description Ftp server
  port-object range 5700 6500
object-group service ftp5700 tcp-udp
  port-object range 5700 7700
object-group service AS2Transmission tcp
  description For AS 2 Transmission 4080,7080,9080
  port-object eq 4080
  port-object eq 7080
  port-object eq 9080
  description Am servers for TLS
  network-object "xxxxx".xxx.com255.255.255.255
  network-object "xxxxx"xxx.com255.255.255.255
object-group service MailScannerGroup tcp-udp
  description MailScanner related ports
  port-object eq 6277
  port-object eq 24441
  port-object eq 2703
  port-object eq echo
  port-object eq 873
  description For Accounting PayChex
object-group service PAYPAL tcp
  description on artur's request
  port-object eq 1433
object-group service SAP tcp
  port-object range 3201 3201
  port-object range 50100 50100
object-group service Packet8 tcp
  description Port 6252 for packet8 billing
  port-object range 6252 6252
object-group service "xxxxx" tcp
  description aport website
  port-object range 90 90
object-group service L2TP udp
  description L2TP VPN Ports
  port-object range isakmp isakmp
  port-object range 1701 1701
  port-object range 4500 4500
  port-object range 50 50
object-group service L2TP2 tcp-udp
  description L2TP
  port-object range 1723 1723
  port-object range 500 500
object-group service port8005 tcp
  description hosting applications for OurDomain
  port-object range 8005 8005
object-group service Polycom-1720 tcp
object-group service Polycom-3230-3243 tcp
  port-object range 3230 3243
object-group service Polycom-3230-3285 udp
  port-object range 3230 3285
object-group service snmp_port tcp
  port-object range 161 162
object-group service port8889 tcp
  port-object range 8889 8889
  port-object range 8080 8080
object-group network temp
object-group network everyone
  network-object ian 255.255.255.255
access-list inside_outbound_nat0_acl permit ip host "xxxxx"
access-list inside_outbound_nat0_acl permit ip host "xxxxx" any
access-list inside_outbound_nat0_acl permit ip host w"xxxxx"any
access-list inside_outbound_nat0_acl permit ip host "xxxxx"2 any
access-list inside_outbound_nat0_acl permit ip host "xxxxx"-"xxxxx" any
access-list inside_outbound_nat0_acl permit ip any any
no pager
logging on
logging timestamp
logging trap notifications
logging history informational
icmp deny host 69.xx.xx.10 outside
mtu outside 1500
mtu inside 1500
mtu RESCUE 1500
mtu NewBlock 1500
ip address outside 69.xx.xx.10 255.255.255.252
ip address inside 69.xx.xxx.129 255.255.255.192
ip address RESCUE 10.x.x.1 255.255.255.0
ip address NewBlock 173.xxx.xx.65 255.255.255.224
ip verify reverse-path interface outside
ip audit info action alarm
ip audit attack action alarm
failover
failover timeout 0:00:00
failover poll 15
no failover ip address outside
no failover ip address inside
no failover ip address RESCUE
no failover ip address NewBlock
pdm location "xxxxx" 255.255.255.255 inside
pdm location "xxxxx"-"xxxxx" 255.255.255.255 inside
pdm location "xxxxx" 255.255.255.255 outside
pdm location "xxxxx"255.255.255.255 inside
pdm location "xxxxx".xxx.com255.255.255.255 outside
pdm location Ce"xxxxx""xxxxx" 255.255.255.255 inside
pdm location 192.168.200.249 255.255.255.255 inside
pdm location 69.xx.xxx.190 255.255.255.255 inside
pdm location johntest2 255.255.255.255 NewBlock
pdm location johntest2 255.255.255.255 inside
pdm location johntest3 255.255.255.255 NewBlock
pdm location NBFirewall 255.255.255.255 inside
pdm location NBFirewall 255.255.255.255 NewBlock
pdm location johntest3 255.255.255.255 inside
pdm group EveryOneInsideGroup inside
pdm group http_httpsGroup inside
pdm group publicpool inside
pdm group "xxxxx" inside
pdm group VPNboxes inside
pdm group "xxxxx" outside
pdm group temp inside
pdm group DemoNetworkPublicGroup inside
pdm group everyone NewBlock
pdm logging informational 100
pdm history enable
arp timeout 14440
global (inside) 1 69.xxx.xx.xxx-69.xx.xxx.xxx
global (NewBlock) 1 173.xx.xx.xx-173.xxx.xxx.xx
nat (inside) 0 access-list inside_outbound_nat0_acl
static (NewBlock,outside) johntest2 johntest2 netmask 255.255.255.255 0 0
static (NewBlock,outside) NBFirewall NBFirewall netmask 255.255.255.255 0 0
static (NewBlock,outside) johntest3 johntest3 netmask 255.255.255.255 0 0
static (NewBlock,outside) johntest4 johntest4 netmask 255.255.255.255 0 0
conduit permit gre host "xxxxx" any
conduit permit tcp host "xxxxx" object-group port8889 any
conduit permit esp host "xxxxx" any
conduit permit ah host "xxxxx" any
conduit permit udp host "xxxxx" eq isakmp any
conduit permit udp host "xxxxx" eq 4500 any
conduit permit tcp host "xxxxx" eq 10000 any
conduit permit udp host "xxxxx" eq 10000 any
conduit permit udp object-group "xxxxx" eq domain any
conduit permit tcp object-group "xxxxx" eq domain any
conduit permit tcp host FTP eq ftp any
conduit permit tcp host FTP eq ftp-data any
conduit permit tcp host FTP object-group ftp5700 any
conduit permit tcp object-group DemoNetworkPublicGroup eq www any
conduit permit tcp object-group DemoNetworkPublicGroup eq https any
conduit permit tcp object-group http_httpsGroup eq www any
conduit permit tcp object-group http_httpsGroup eq https any
conduit permit tcp host "xxxxx" eq www any
conduit permit tcp host "xxxxx" eq 3101 any
conduit permit tcp host "xxxxx" eq ssh any
conduit permit tcp host "xxxxx" object-group AS2Transmission any
conduit permit tcp host "xxxxx" eq smtp any
conduit permit tcp host "xxxxx" eq smtp object-group AmgenMXGroup
conduit permit tcp host "xxxxx" eq citrix-ica any
conduit permit tcp host "xxxxx" eq 7001 any
conduit permit tcp host 69.xx.xxx.190 eq 9080 any
conduit permit tcp host 69.xx.xxx.190 eq 7001 any
conduit permit tcp host "xxxxx" eq 7080 any
conduit permit tcp host "xxxxx" object-group SAP any
conduit permit tcp host "xxxxx" any
conduit permit tcp host xxxxxx eq www any
conduit permit tcp host "xxxxx" object-group agsupport any
conduit permit tcp host "xxxxx" eq pptp any
conduit permit udp host "xxxxx" object-group L2TP any
conduit permit tcp host "xxxxx" eq https any
conduit permit tcp host "xxxxx" eq 4080 any
conduit permit tcp host "xxxxx" eq 8001 any
conduit permit tcp host "xxxxx" eq 9080 any
conduit deny tcp any any
conduit deny udp any any
conduit deny icmp any any
conduit permit tcp host "xxxxx" eq h323 any
conduit permit tcp host "xxxxx" object-group Polycom-1720 any
conduit permit tcp host "xxxxx" object-group Polycom-3230-3243 any
conduit permit udp host "xxxxx" object-group Polycom-3230-3285 any
conduit permit tcp host "xxxxx" object-group BizConnect any
outbound   1 permit "xxxxx" 255.255.255.255 53 udp
outbound   1 permit "xxxxx" 255.255.255.255 25 tcp
outbound   1 permit "xxxxx" 255.255.255.255 1494 tcp
outbound   1 permit "xxxxx" 255.255.255.255 123 udp
outbound   1 permit "xxxxx" 255.255.255.255 3101 tcp
outbound   1 permit 0.0.0.0 0.0.0.0 80 tcp
outbound   1 permit 0.0.0.0 0.0.0.0 443 tcp
outbound   1 permit "xxxxx"-"xxxxx" 255.255.255.255 443 tcp
outbound   1 permit 0.0.0.0 0.0.0.0 500 udp
outbound   1 permit 0.0.0.0 0.0.0.0 0 ah
outbound   1 permit 0.0.0.0 0.0.0.0 0 esp
outbound   1 permit 0.0.0.0 0.0.0.0 0 gre
outbound   1 permit 0.0.0.0 0.0.0.0 53 tcp
outbound   1 permit 0.0.0.0 0.0.0.0 53 udp
outbound   1 permit 0.0.0.0 0.0.0.0 10000 tcp
outbound   1 permit 0.0.0.0 0.0.0.0 4500 udp
outbound   1 permit 0.0.0.0 0.0.0.0 10000 udp
outbound   1 permit 0.0.0.0 0.0.0.0 3302 tcp
outbound   1 permit "xxxxx" 255.255.255.255 0 gre
outbound   1 permit "xxxxx" 255.255.255.255 1723 tcp
outbound   1 permit "xxxxx" 255.255.255.255 20-21 tcp
outbound   1 permit "xxxxx" 255.255.255.255 9080 tcp
outbound   1 permit "xxxxx" 255.255.255.255 7080 tcp
outbound   1 permit "xxxxx" 255.255.255.255 4080 tcp
outbound   1 deny 0.0.0.0 0.0.0.0 0 udp
outbound   1 deny 0.0.0.0 0.0.0.0 0 tcp
outbound   1 permit "xxxxx" 255.255.255.255 5060-5061 udp
outbound   1 permit "xxxxx" 255.255.255.255 10000-20000 udp
outbound   1 permit "xxxxx" 255.255.255.255 5060-5061 tcp
outbound   1 permit "xxxxx" 255.255.255.255 5700-7700 tcp
outbound   1 permit "xxxxx" 255.255.255.255 0 udp
outbound   1 permit "xxxxx" 255.255.255.255 20-22 tcp
outbound   1 permit "xxxxx" 255.255.255.255 0 esp
outbound   1 permit "xxxxx" 255.255.255.255 0 tcp
outbound   1 permit 0.0.0.0 0.0.0.0 8005 tcp
outbound   1 permit "xxxxx" 255.255.255.255 1720 tcp
outbound   1 permit "xxxxx" 255.255.255.255 8001 tcp
outbound   2 permit "xxxxx" 255.255.255.255 21 tcp
outbound   2 permit "xxxxx" 255.255.255.255 0 icmp
outbound   2 permit "xxxxx" 255.255.255.255 0 udp
outbound   2 permit "xxxxx" 255.255.255.255 0 tcp
outbound   2 permit "xxxxx" 255.255.255.255 500 udp
outbound   2 permit "xxxxx" 255.255.255.255 0 ah
outbound   2 permit "xxxxx" 255.255.255.255 0 esp
outbound   2 permit "xxxxx" 255.255.255.255 0 gre
outbound   2 permit "xxxxx" 255.255.255.255 0 ip
outbound   2 permit "xxxxx" 255.255.255.255 20 tcp
outbound   2 permit "xxxxx" 255.255.255.255 5601 tcp
apply (inside) 1 outgoing_src
apply (inside) 2 outgoing_dest
route outside 0.0.0.0 0.0.0.0 69.xx.xx.9 1
route inside NBFirewall 255.255.255.255 69.xx.xxx.143 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout sip-disconnect 0:02:00 sip-invite 0:03:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server TACACS+ max-failed-attempts 3
aaa-server TACACS+ deadtime 10
aaa-server RADIUS protocol radius
aaa-server RADIUS max-failed-attempts 3
aaa-server RADIUS deadtime 10
aaa-server RADIUS (inside) host TCS04 DomainTest timeout 5
aaa-server LOCAL protocol local
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
aaa authorization command LOCAL
http server enable
http "xxxxx" 255.255.255.255 inside
snmp-server host inside 192.168.200.249
snmp-server location
snmp-server contact
snmp-server community DomainN
snmp-server enable traps
tftp-server inside ESM632 TFTP-Root
floodguard enable
sysopt noproxyarp inside
sysopt noproxyarp NewBlock
auth-prompt prompt Welcome to OurDomain Network
auth-prompt accept Access Allowed
auth-prompt reject Please verify the user account details
isakmp nat-traversal 20
telnet timeout 5
ssh "xxxxx" 255.255.255.255 inside
ssh timeout 5
console timeout 0
username root password sIdfd"xxxxx"2aHgdfgOMsI encrypted privilege 15
privilege show level 0 command version
privilege show level 0 command curpriv
privilege show level 3 command pdm
privilege show level 3 command blocks
privilege show level 3 command ssh
privilege configure level 3 command who
privilege show level 3 command isakmp
privilege show level 3 command ipsec
privilege show level 3 command vpdn
privilege show level 3 command local-host
privilege show level 3 command interface
privilege configure level 3 command ping
privilege show level 3 command uauth
privilege configure level 5 mode enable command configure
privilege show level 5 command running-config
privilege show level 5 command privilege
privilege show level 5 command clock
privilege show level 5 command ntp
privilege show level 5 mode configure command logging
privilege show level 5 command fragment
terminal width 80
Cryptochecksum:8c73f"xxxxx"a6024b8c
: end
Hi Jon,
What commands do you think I should run for my ACL's?
Also, you suggest removing the conuit statements?
John
