IOS Features
bradlesliect
I have the latest ver of an IOS for 837:
c837-k9o3y6-mz.124-10a.bin
How do I find out what it supports?
6 Replies 6
spremkumar
Level 9
Level 9
Hi Brad
Hope this links helps u to find out the feature your ios code supports..
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
regds
thank you ...but .... 🙂
what is the diff between IP/FW 3DES and IP/FW/PLUS 3DES
mheusinger
Level 10
Level 10
Usually the IOS feature navigator can help you: www.cisco.com/go/fn
You will find a link Search by software and another link search by platform. Either way you should find your combination.
One word of caution out of personal experience, though: not every feature might be listed and the FN might just not be up to date. So my suggestion is to also have a look at the configuration guide and command reference or at "Cisco IOS Software Release 12.4 Features and Hardware Support"
http://www.cisco.com/en/US/products/ps6350/prod_bulletin09186a0080457b39.html
Hope this helps! Please rate all posts.
Regards, Martin
thanks ...man cisco site not really that easy to nav.
"New ROMmon will be released for Cisco83x, Cisco828 and Cisco SOHO 90 Series platforms."
where would i find the above and why would you use it if your router is a production / live router?
amit-singh
Level 8
Level 8
Hi Friend,
837 comes by default with security image loaded on it. The router that you have is with Secuirty plus image on 837 router with IP/Firewall/IPSec 3DES.
Please see the link below for more explanation on the features that it supports :
http://www.cisco.com/en/US/products/hw/routers/ps380/products_data_sheet09186a008010e5c5.html
HTH,
-amit singh
Thank you. Taking a look now. How do i find the latest ROMmon version for the 837? .... 🙂
