IOS from Sup 720 to RSP 720 in 7600
mathurmahesh
HI , i have a query ,we are planning to upgrade the Sup Engine from WS-SUP720-3B 2 ports Supervisor Engine 720 to
RSP720-3CXL-GE=
Cisco 7600 Route Switch Processor 720Gbps fabric,PFC3CXL, GE
Can we use the same old IOS from Sup720 to the New RSP720 without purchasing it ???
Show  Version-- Cisco Router 7609
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRB3, RELEASE SOFTWARE (fc
1)
ROM: System Bootstrap, Version 12.2(17r)S4, RELEASE SOFTWARE (fc1)
System returned to ROM by  power cycle at 08:36:39 PDT Fri Mar 30 2007 (SP by power on)
System restarted at 10:04:20 GMT Fri Nov 25 2011
System image file is "bootdisk:c7600s72033-advipservicesk9-mz.122-33.SRB3.bin"
Last reload type: Normal Reload
cisco CISCO7609 (R7000) processor (revision 1.2) with 458720K/65536K bytes of memory.
Processor board ID FOX10520U0G
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from s/w reset
1 SIP-400 controller (4 GigabitEthernet).
3 Virtual Ethernet interfaces
80 Gigabit Ethernet interfaces
4 Ten Gigabit Ethernet interfaces
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Inventory details
NAME: "CISCO7609", DESCR: "Cisco Systems Cisco 7600 9-slot Chassis System"
NAME: "module 5", DESCR: "WS-SUP720-3B 2 ports Supervisor Engine 720 Rev. 5.3"
PID: WS-SUP720-3B      , VID: V03
NAME: "module 6", DESCR: "WS-SUP720-3B 2 ports Supervisor Engine 720 Rev. 5.3"
PID: WS-SUP720-3B      , VID: V03,
Regards ,
Nagendra Kumar Nainar
c7600s72033xxx is for SUP720. For RSP720, you need to download rsp72043xx based image.
-Nagendra
You mean to say that we need to purchase the Adavance IP Services?? and the existing cannot be used..
Hello Mathurmahesh,
you cannot use the same image as RSP 720 has different hardware specially MSFC4, instead of MSFC3 that is in sup 720.
The feature set has to be appropriate for the functionalities you need to run on the C7600 box.
Hope to help
Giuseppe
