Frame-relay lab Configuration
CBESTBONE_2
I was wondering if someone can look at my configuration and tell me what I might be doing wrong in this frame relay configuration? Router 1 is the only one that works. Routers 2&3 line comes up, but the protocol is down. I have been messing with this for a couple of days and cannot figure out what I am doing wrong. I know it has to be a layer 2 issue (frame realy connection issue) Below are my lab configs. Does anything stand out?
frame-relay switching
interface Serial1/0
no ip address
encapsulation frame-relay
clock rate 64000
frame-relay intf-type dce
no frame-relay inverse-arp
frame-relay route 122 interface Serial1/1 221
frame-relay route 123 interface Serial1/2 321
no shut
interface Serial1/1
no ip address
frame-relay route 221 interface Serial1/0 122
no shut
interface Serial1/2
no ip address
clock rate 64000
frame-relay route 321 interface Serial1/0 123
no shut
R1
int lo1
ip address 1.1.1.1 255.255.255.255
exit
int fa0/0
ip address 10.1.1.1 255.255.255.0
no shut
exit
int s0/0
ip address 172.12.123.1 255.255.255.0
frame-relay map ip 172.12.123.2 122 broadcast
frame-relay map ip 172.12.123.3 123 broadcast
no shut
R2
int lo2
ip address 2.2.2.2 255.255.255.255
exit
int fa0/0
ip address 172.12.234.2 255.255.255.0
no shut
exit
int s0/0
ip address 172.12.123.2 255.255.255.0
clock rate 64000
frame-relay map ip 172.12.123.1 221 broadcast
no shut
R3
int lo3
ip address 3.3.3.3 255.255.255.255
exit
int fa0/0
ip address 172.12.234.3 255.255.255.0
no shut
exit
int s0/0
ip address 172.12.123.3 255.255.255.0
frame-relay map ip 172.12.123.1 321 broadcast
no shut
int s1/0
ip address 172.12.34.3 255.255.255.0
no shut
Your FRS config looks okay apart from the intf-type on Ser1/1 ( which has already been highlighted) and I dont see the lmi type stated anywhere on the routers I assume its cisco?- sh frame-relay lmi interface serial x/x | in LMI
Your hardware is ok? -( cabling/ports etc..)
Have you tried erasing the FRS and the routers  and re-adding the config?
res
Paul
Please don't forget to rate this post if it has been helpful.
Kind Regards
Paul
8 Replies 8
Peter Paluch
Your Serial1/1 interface on the Frame Relay switching router is missing the frame-relay intf-type dce command. Please note that the FR DCE/DTE definition is absolutely independent of what kind of cable (physical DCE/DTE) is connected to the interface. In FR, the DCE end is responsible for responding to LMI queries (i.e the FR switch) while the DTE is the end device that sends LMI queries (i.e. the R1, R2, R3 routers).
Try adding the frame-relay intf-type dce to your S1/1 interface and see if this helps.
Best regards,
Peter
Thanks, Peter, but I originally had that in. As I stated, I have been working on this for over two days. I’ve been changing DTE and DCEs so much, I had to replace one of the cables as a pin got bent. The configuration I cut and pasted did not have it in. That is not the issue, but what else do you have? I truly appreciate the response
Just to make sure we understand each other, it is mandatory to have the frame-relay intf-type dce command on all serial interfaces of the router that acts as the frame relay switch, and it must not be used on any of the R1, R2 or R3 interfaces.
Regarding the R2 and R3 not reporting line protocol up, this is a set of suggestions:
  • Check whether the show controllers s0/0 reports that a correct cable type is detected and that the clocks are either set or detected. Messages similar to "clocks stopped", "clock not detected", "clock not set" indicate a problem with clock rate setting.
  • Check the output of the show frame-relay pvc whether there are any DLCIs detected and reported.
  • Check the output of show interface s0/0 on both R2, R3 and the FR switch whether there are any input errors recorded. They would suggest that a physical problem exists.
  • If nothing helps, try simply configuring the links between R2/R3 and FR using HDLC encapsulation and unique IP adresses and try pinging the devices. We need to be sure that this ping works. If it does not work then there is a different underlying problem and we should be focusing on that.
Best regards,
Peter
I did all of that in which you asked before, but I am willing to do each step again, except for the last bullet. I know the HDLC links say up, and did the pinging already. I will let you know how I made out. Thanks again for your assistance.
The frame-relay intf-type dce is back in. -- no go
The show controllers on all 4 routers display the clock rate on the dce and tye type (dce/dte) of connections correctly.
In the show frame-relay pvc 1 deleted in router 3, 2 inactive in router 1 and 1 deleted in router 2. (none are active)
In the show interface command, no input errors.
I ran the last one just to be thorough. I configured them for hdlc, and I am able to ping from both routers to the one I have configured as the frame relay. 100% replies.
you should verify that your routers are plugged on the correct interfaces on the frame-relay switch.
Alain
Check, and still does not work.
res
Paul
Kind Regards
Paul
