ios fw session delete
dragec
How can I clear ip sess on router with fw ios. I can see it by sh ip
inspect but can I clear it somehow?
thx
kamal-learn
Level 4
Level 4
hi
there is a command that can be bad as it can be good no ip inspect name protocol(for a specific protocol), or just no ip inspect name (for the rule), this command will clear all the sessions, it will remove all the dynamic ACL created by the inspection rule, it will also set all global timer and threshold to its default values so be aware of its behavior.
do rate the post if it does help
