IOS Image doesn't loading
Sergio Lima
Hi guys,
I've a problem with a router 2811:
Upgrade ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0xe360d8
Self decompressing the image : ###################################################################################################################################################### [OK]
Error : uncompressed image checksum is incorrect 0xDE173CB2
        Expected a checksum of 0x05173CB3
*** System received a Software forced crash ***
signal= 0x17, code= 0x9, context= 0x80014ac0
PC = 0x8000f0d4, Cause = 0x20, Status Reg = 0x3040a803
c2811 platform with 524288 Kbytes of main memory
Main memory is configured to 64 bit mode with ECC enabled
Error : uncompressed image checksum is incorrect 0xE7173CB2
open(): Open Error = -13
loadprog: error - on file open
boot: cannot load "flash:c2800nm-spservicesk9-mz.124-15.T12.bin"
I tried to boot using usb key:
boot usbflash0:c2800nm-spservicesk9-mz.124-24.T5.bin
But haven't success also.
Someone can help me?
16 Replies 16
System Bootstrap, Version 12.3(11r)T2, RELEASE SOFTWARE (fc1)
Copyright (c) 2005 by cisco Systems, Inc.
System Bootstrap, Version 12.4(13r)T10, RELEASE SOFTWARE (fc1)
Copyright (c) 2008 by cisco Systems, Inc.
Total memory size = 1024 MB - DIMM0 = 512 MB, DIMM1 = 512 MB
c3845 platform with 1048576 Kbytes of main memory
Main memory is configured to 72/72(dimm 0/1) bit mode with ECC enabled
program load complete, entry point: 0x8000f000, size: 0xcb40
boot: cannot load "flash:c3845-spservicesk9-mz.124-25c.bin"
Entering rommon> prompt after several failed attempts to boot an IOS image.
Please check your internal/external flash drives for the correct IOS image
and issue 'reset' at the rommon> prompt to re-try the boot process.
Can you tell me if this is a hardware failure as well?
Error message is tell me the CF is missing.
