IOS needed on 2620
brian-utter
I am trying to figure out what IOS is needed on my 2620 to be able to run the command "crypto key generate ...".
Thank you
cpubob
You'll need a security enabled IOS, so look through the upgrade planner for an IOS that has IPSEC or 3DES or 56 in the description, or if you only have file names, look for K9 in the name.
GL
nordick26
this one should be ok:
c2600-adventerprisek9-mz.123-8.ZA1.bin
You can use IOS navigator tool:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Ivan
[rate any helpful posts]
cpubob
GL
andychua.chua
cryto key generate, use Advance security already enough.
