IOS Noob here, load-balancing and/or fail over configuration
BledarShehu
Hello There,
Firstly a brief introduction of what i have:
A cisco 1941 Router + HWIC-2FE
2 Static IP Incoming Lines (Both of them 5mb UP/Down)
Now i have seen all over the forums what i could find , and i have setup a SLA fail over, but for some reason it alaways gives problem , if anoyone is kind enough to have time and some solution at least for fail over and not for Load-Balancing , it would be really appriciated .
Thanks for your time
cadet alain
post your config and topology it will be easier to troubleshoot.
Regards.
Alain
Ok thanks , here is the config :
no aaa new-model
no ipv6 cef
no ip subnet-zero
no ip source-route
ip cef
ip domain name 8milalb.loc
ip name-server 208.67.222.222
ip name-server 208.67.220.220
ip port-map sip port udp 5060 list 2 description SIP
redundancy
track 1 ip sla 1 reachability
delay down 9 up 10
track 2 ip sla 2 reachability
delay down 9 up 10
interface GigabitEthernet0/0
description WAN$ETH-WAN$
ip address 109.69.1.110 255.255.255.248
ip load-sharing per-packet
ip nat outside
ip virtual-reassembly
no ip route-cache cef
duplex auto
speed auto
arp timeout 3
interface GigabitEthernet0/1
description LAN$ES_LAN$$ETH-LAN$
ip address 192.168.10.1 255.255.254.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/0/0
description TRINNG$ETH-WAN$
ip address 95.107.1.6 255.255.255.252
ip nat outside
duplex auto
speed auto
arp timeout 3
interface FastEthernet0/0/1
no ip address
shutdown
duplex auto
speed auto
no ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
no ip nat service sip udp port 5060
ip nat inside source route-map ABCOM interface GigabitEthernet0/0 overload
ip nat inside source route-map TRING interface FastEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 track 1
ip route 0.0.0.0 0.0.0.0 FastEthernet0/0/0 100 track 2
ip sla 1
icmp-echo 109.69.1.1 source-interface GigabitEthernet0/0
timeout 1000
threshold 5
frequency 5
ip sla schedule 1 life forever start-time now
ip sla 2
icmp-echo 95.107.10.1 source-interface FastEthernet0/0/0
timeout 1000
threshold 3
frequency 3
ip sla schedule 2 life forever start-time now
no logging trap
route-map ABCOM permit 10
match interface GigabitEthernet0/0
route-map TRING permit 10
match interface FastEthernet0/0/0
snmp-server community public RO
snmp-server ifindex persist
control-plane
exception protocol ftp
scheduler allocate 20000 1000
end
fb_webuser
Level 6
Level 6
This should help:
considering gig0/0 connects to 1st isp and gig0/1 connects to 2nd isp
ip route 4.2.2.2 255.255.255.255 <1st isp gateway> permanent
track1 ip route 4.2.2.2 reachability
ip route 0.0.0.0 0.0.0.0 <1st isp gateway> track 1
ip route 0.0.0.0 0.0.0.0 <2nd isp gateway> 10
ip nat inside source route-map ISP1 gig0/0 overload
ip nat inside roure route-map ISP2 gig0/1overload
route-map ISP1
match interface gig0/0
route-map ISP2
match int gig0/1
Mukti
Posted by WebUser Mukti Chandwani
