WAN failover over 4G wireless
marramix01
I am currently working on a project to bring up a 4G\3G secondary connection (failover) in case the main MPLS link fails.
The set up is something like that:
The goal is to make sure the 4G kicks in when the main mpls ckt goes down
I have tried by puting static routes from the remote site point to the tu0 with higher cost, all that is good, untill you get to the HQ-MPLS router wich it is not redistributing the static routes into osfp (by design - since there are some static routes on hq-mpls) and when you insert redistribute static statement we observe routing loops for those static routes on the hq-mpls router.
I dont mind running other igp protocol in order to accomplish the goal (remote and hq) and then redistribute into bgp and back.
Can someone share some knowledge\suggestion\documentation, etc
Thanks again,
marramix01
a.ascione
I would configure a secondary bgp connection for this over the 4G cloud.
with the local preference attribute you can select the MPLS path as primary path (for incoming routes)
for outgoing routes you can prepend your own as on the backup path.
That should do the trick
regards
Thanks for the quick response. I will be playing with it next week.
marramix01
well this is depend on how you do your routing over the 4G
if you are using only static route and BGP over the MPLS then you job is simple
you need to advertise a network ( dummy ) between the two MPLS edge drouters you have and advertise it over BGP
use a watcher on each of the routers to watch that route once this route disapeared from the routing table the 4G will start
also use an IPSLA track to watch this route once its disapeared from the routing table a static route over the 3G will comes up
Make sure the avertised dummy network over BGP is not covered with this static route
example:
in the HQ mpls create a loopback and advertise it in BGP
in lo0
ip address 1.1.1.1 255.255.255.255
router bgp xx
network 1.1.1.1 mask 255.255.255.255
remote router
track 5 ip route 1.1.1.1/32 reachability
delay down 3 up 3
track 10 list boolean and  ------ this will consider track 10 down when the route 1.1.1.1/32 is in the routing table
object 5 not
ip route 0.0.0.0 0.0.0.0 interface dialerxx track 10     --- this static route will be down in the case the bgp route 1.1.1.1/32 is in the routing table which means BGP link is up you might use the 4G next hope ( depends on the service provider setup )
the below can be used to bring the 4g interface up when the route 1.1.1.1/32 is not in the routing table
dialer watch-list 1 ip 1.1.1.1 255.255.255.255
dialer watch-list 1 delay route-check initial 180
dialer watch-list 1 delay connect 60
dialer-list 1 protocol ip permit
interface Dialerxx   - 4G int
dialer pool 1
dialer watch-group 1
hope this help
if helpful rate
I will be deploying the 4G tonight. Lets see how it goes. I took your advice (config sample) and twicked it a little bit.
Thanks for the help.
marramix01
