IOS not showing in FLASH
John Bachman
I noticed the ISO had disappeared from flash and I get this error on booting:.
%Error opening c2800nm-adventerprisek9-mz.124-11.XJ4.bin (file not found)
The router boots ok and works great, I have lots of stuff for my CME in there and I do not feel like formatting the flash...
Any idea how I can see the IOS so I can remove it and upgrade it ? I even tried to FTP the c2800nm-adventerprisek9-mz.124-11.XJ4.bin  to an outside server, it fails after 33MB.
I do not have boot image secure as the file is "missing" , the router does not allow the command to go thru.
Any help is appreciated.
As you see: lines 1 and 2 are missing, it starts at "3"
guess 1 or  2 must be the line for IOS
2811#sh flash
3            0 Jan 31 2013 13:22:30 -05:00 bacdprompts
4        18836 Jan 31 2013 13:22:32 -05:00 bacdprompts/app-b-acd-2.1.2.2-ReadMe.txt
5        75650 Jan 31 2013 13:22:32 -05:00 bacdprompts/en_bacd_allagentsbusy.au
6        83291 Jan 31 2013 13:22:32 -05:00 bacdprompts/en_bacd_disconnect.au
7        63055 Jan 31 2013 13:22:34 -05:00 bacdprompts/en_bacd_enter_dest.au
8        37952 Jan 31 2013 13:22:34 -05:00 bacdprompts/en_bacd_invalidoption.au
9       496521 Jan 31 2013 13:22:38 -05:00 bacdprompts/en_bacd_music_on_hold.au
10      123446 Jan 31 2013 13:22:38 -05:00 bacdprompts/en_bacd_options_menu.au
11       42978 Jan 31 2013 13:22:40 -05:00 bacdprompts/en_bacd_welcome.au
12       34794 Jan 31 2013 13:22:40 -05:00 bacdprompts/en_bacd_xferto_operator.au
13       19566 Jan 31 2013 13:22:40 -05:00 CME42-full-readme-v.1.0.txt
14           0 Jan 31 2013 13:22:40 -05:00 CP7921G-1.0.3
15         871 Jan 31 2013 13:22:42 -05:00 CP7921G-1.0.3/CP7921G-1.0.3.LOADS
16     1868518 Jan 31 2013 13:22:50 -05:00 CP7921G-1.0.3/APPS-1.0.3.SBN
17     1461170 Jan 31 2013 13:22:56 -05:00 CP7921G-1.0.3/GUI-1.0.3.SBN
18     2078210 Jan 31 2013 13:23:04 -05:00 CP7921G-1.0.3/SYS-1.0.3.SBN
19      893001 Jan 31 2013 13:23:08 -05:00 CP7921G-1.0.3/TNUX-1.0.3.SBN
20     2196478 Jan 31 2013 13:23:18 -05:00 CP7921G-1.0.3/TNUXR-1.0.3.SBN
21     1300663 Jan 31 2013 13:23:24 -05:00 CP7921G-1.0.3/WLAN-1.0.3.SBN
22           0 Jan 31 2013 13:23:24 -05:00 Desktops
23           0 Jan 31 2013 13:23:24 -05:00 Desktops/320x212x12
24      131470 Jan 31 2013 13:23:26 -05:00 Desktops/320x212x12/CampusNight.png
25       80565 Jan 31 2013 13:23:26 -05:00 Desktops/320x212x12/CiscoFountain.png
26      138278 Jan 31 2013 13:23:28 -05:00 Desktops/320x212x12/Fountain.png
27      109076 Jan 31 2013 13:23:30 -05:00 Desktops/320x212x12/MorroRock.png
28      108087 Jan 31 2013 13:23:30 -05:00 Desktops/320x212x12/NantucketFlowers.png
29       10820 Jan 31 2013 13:23:30 -05:00 Desktops/320x212x12/TN-CampusNight.png
30        9657 Jan 31 2013 13:23:32 -05:00 Desktops/320x212x12/TN-CiscoFountain.png
31        7953 Jan 31 2013 13:23:32 -05:00 Desktops/320x212x12/TN-Fountain.png
32        7274 Jan 31 2013 13:23:34 -05:00 Desktops/320x212x12/TN-MorroRock.png
33        9933 Jan 31 2013 13:23:34 -05:00 Desktops/320x212x12/TN-NantucketFlowers.png
34         628 Jan 31 2013 13:23:34 -05:00 Desktops/320x212x12/List.xml
35           0 Jan 31 2013 13:23:34 -05:00 gui
36        4802 Jan 31 2013 13:23:36 -05:00 gui/admin_user.html
37      657587 Jan 31 2013 13:23:38 -05:00 gui/admin_user.js
38        1602 Jan 31 2013 13:23:40 -05:00 gui/CiscoLogo.gif
39         619 Jan 31 2013 13:23:40 -05:00 gui/CME_GUI_README.TXT
40         953 Jan 31 2013 13:23:40 -05:00 gui/delete.gif
41       16344 Jan 31 2013 13:23:42 -05:00 gui/dom.js
42         864 Jan 31 2013 13:23:42 -05:00 gui/downarrow.gif
43        6146 Jan 31 2013 13:23:42 -05:00 gui/ephone_admin.html
44        4658 Jan 31 2013 13:23:44 -05:00 gui/logohome.gif
45        3724 Jan 31 2013 13:23:44 -05:00 gui/normal_user.html
-----------snip--------------------
Once the problem fixed, I would like to upgrade my IOS from c2800nm-adventerprisek9-mz.124-11.XJ4.bin to c2800nm-adventerprisek9-mz.124-20.YA2.bin
John,
Please let's get back to that software I have suggested. You have used it incorrectly, as you have selected your hard disk as the target. That is not what I had in mind - what I need is a file image of the CF card. Let's do it once again, here are the steps.
After starting the program, in the first screen, select the CF card just as you did and click on the Continue button. Then, in the target selection screen, double-click the FILE option in the list and insert the name of the file you want to save the image as. In the same file save window, select the type of image: "Raw image (dd image)". Then click on the Continue button again. In the next screen, it should not warn you about formatting a drive anymore, and after clicking on the START button, the CF card shall be stored as an image.
I understand that your issues may be solved with the new CF card but this is such an obscure error that I am extremely strongly interested in learning what really happened. Please be patient with me here and try to go over this exercise once again. Thank you!
Best regards,
Peter
29 Replies 29
James Neilson
does a dir flash: show anything?
You could try a delete flash:c2800nm-adventerprisek9-mz.124-11.XJ4.bin If you are just wanting to remove the file
Thank you, James,
Not really showing more.
c2800nm-adventerprisek9-mz.124-11.XJ4.bin is my production IOS, If I remove it, the router wont run...
Beside, I doutb I can remove it as the router does not see it.
2811#dir flash:
Directory of flash:/
    3  drw-           0  Jan 31 2013 13:22:30 -05:00  bacdprompts
   13  -rw-       19566  Jan 31 2013 13:22:40 -05:00  CME42-full-readme-v.1.0.txt
   14  drw-           0  Jan 31 2013 13:22:40 -05:00  CP7921G-1.0.3
   22  drw-           0  Jan 31 2013 13:23:24 -05:00  Desktops
   35  drw-           0  Jan 31 2013 13:23:34 -05:00  gui
   54  -rw-      496521  Jan 31 2013 13:23:52 -05:00  music-on-hold.au
   55  drw-           0  Jan 31 2013 13:23:52 -05:00  phone
  102  drw-           0  Jan 31 2013 13:27:34 -05:00  ringtones
  136  drw-           0  Feb 21 2013 21:05:20 -05:00  its
128167936 bytes total (22663168 bytes free)
Thank you Peter,
As I stated in my original post,
Now I do no secure boot-image fom the console, and it confrms  IOS relisience is not active
Peter Paluch
John,
There is a remote possibility that the IOS Resiliency (secure boot-image) has been activated in the past but the original configuration has been lost so the router does not "remember" the IOS Resiliency was activated.
Try entering these two commands in the global configuration while accessing the router via the console port (not remotely!):
secure boot-image ! may produce error messages - ignore them
Afterwards, check whether the IOS has been reinstated into the FLASH.
Best regards,
Peter
Hello
You can also post
Sh ver
Sh boot
Could be the iOS is in one or the flash directories
Res
Paul
Kind Regards
Paul
Thank you Paul,
Sh boot command does not exist
I know the IOS exists somewhere because the router boots ok.
2811#sh ver
Cisco IOS Software, 2800 Software (C2800NM-ADVENTERPRISEK9-M), Version 12.4(11)XJ4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Fri 13-Jul-07 22:43 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
2811 uptime is 2 hours, 52 minutes
System restarted at 09:28:49 PCLAIRE Thu Aug 1 2013
System image file is "flash:c2800nm-adventerprisek9-mz.124-11.XJ4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 2811 (revision 53.51) with 509952K/14336K bytes of memory.
Processor board ID FHK1302F0YV
3 FastEthernet interfaces
24 Serial interfaces
1 Channelized T1/PRI port
1 Virtual Private Network (VPN) Module
DRAM configuration is 64 bits wide with parity enabled.
239K bytes of non-volatile configuration memory.
125440K bytes of ATA CompactFlash (Read/Write)
2811#
John,
Let's try some more brute force, shall we?
Please enter the following command, capture its entire output and post it here if possible. Thank you!
dir /all /recursive flash:/
Best regards,
Peter
2811#dir /all /recursive flash:/
Directory of flash:/*
Directory of flash:/bacdprompts/
    4  -rw-       18836  Jan 31 2013 13:22:32 -05:00  app-b-acd-2.1.2.2-ReadMe.txt
    5  -rw-       75650  Jan 31 2013 13:22:32 -05:00  en_bacd_allagentsbusy.au
    6  -rw-       83291  Jan 31 2013 13:22:32 -05:00  en_bacd_disconnect.au
    7  -rw-       63055  Jan 31 2013 13:22:34 -05:00  en_bacd_enter_dest.au
    8  -rw-       37952  Jan 31 2013 13:22:34 -05:00  en_bacd_invalidoption.au
    9  -rw-      496521  Jan 31 2013 13:22:38 -05:00  en_bacd_music_on_hold.au
   10  -rw-      123446  Jan 31 2013 13:22:38 -05:00  en_bacd_options_menu.au
   11  -rw-       42978  Jan 31 2013 13:22:40 -05:00  en_bacd_welcome.au
   12  -rw-       34794  Jan 31 2013 13:22:40 -05:00  en_bacd_xferto_operator.au
Directory of flash:/CP7921G-1.0.3/
   15  -rw-         871  Jan 31 2013 13:22:42 -05:00  CP7921G-1.0.3.LOADS
   16  -rw-     1868518  Jan 31 2013 13:22:50 -05:00  APPS-1.0.3.SBN
   17  -rw-     1461170  Jan 31 2013 13:22:56 -05:00  GUI-1.0.3.SBN
   18  -rw-     2078210  Jan 31 2013 13:23:04 -05:00  SYS-1.0.3.SBN
   19  -rw-      893001  Jan 31 2013 13:23:08 -05:00  TNUX-1.0.3.SBN
   20  -rw-     2196478  Jan 31 2013 13:23:18 -05:00  TNUXR-1.0.3.SBN
   21  -rw-     1300663  Jan 31 2013 13:23:24 -05:00  WLAN-1.0.3.SBN
Directory of flash:/Desktops/
Directory of flash:/Desktops/320x212x12/
   24  -rw-      131470  Jan 31 2013 13:23:26 -05:00  CampusNight.png
   25  -rw-       80565  Jan 31 2013 13:23:26 -05:00  CiscoFountain.png
   26  -rw-      138278  Jan 31 2013 13:23:28 -05:00  Fountain.png
   27  -rw-      109076  Jan 31 2013 13:23:30 -05:00  MorroRock.png
   28  -rw-      108087  Jan 31 2013 13:23:30 -05:00  NantucketFlowers.png
   29  -rw-       10820  Jan 31 2013 13:23:30 -05:00  TN-CampusNight.png
   30  -rw-        9657  Jan 31 2013 13:23:32 -05:00  TN-CiscoFountain.png
   31  -rw-        7953  Jan 31 2013 13:23:32 -05:00  TN-Fountain.png
   32  -rw-        7274  Jan 31 2013 13:23:34 -05:00  TN-MorroRock.png
   33  -rw-        9933  Jan 31 2013 13:23:34 -05:00  TN-NantucketFlowers.png
   34  -rw-         628  Jan 31 2013 13:23:34 -05:00  List.xml
Directory of flash:/gui/
   36  -rw-        4802  Jan 31 2013 13:23:36 -05:00  admin_user.html
   37  -rw-      657587  Jan 31 2013 13:23:38 -05:00  admin_user.js
   38  -rw-        1602  Jan 31 2013 13:23:40 -05:00  CiscoLogo.gif
   39  -rw-         619  Jan 31 2013 13:23:40 -05:00  CME_GUI_README.TXT
   40  -rw-         953  Jan 31 2013 13:23:40 -05:00  delete.gif
   41  -rw-       16344  Jan 31 2013 13:23:42 -05:00  dom.js
   42  -rw-         864  Jan 31 2013 13:23:42 -05:00  downarrow.gif
   43  -rw-        6146  Jan 31 2013 13:23:42 -05:00  ephone_admin.html
   44  -rw-        4658  Jan 31 2013 13:23:44 -05:00  logohome.gif
   45  -rw-        3724  Jan 31 2013 13:23:44 -05:00  normal_user.html
   46  -rw-       81443  Jan 31 2013 13:23:44 -05:00  normal_user.js
   47  -rw-        1347  Jan 31 2013 13:23:46 -05:00  plus.gif
   48  -rw-         843  Jan 31 2013 13:23:46 -05:00  sxiconad.gif
   49  -rw-         174  Jan 31 2013 13:23:46 -05:00  tab.gif
   50  -rw-        2433  Jan 31 2013 13:23:48 -05:00  telephony_service.html
   51  -rw-         870  Jan 31 2013 13:23:48 -05:00  uparrow.gif
   52  -rw-        3412  Jan 31 2013 13:23:48 -05:00  xml.template
   53  -rw-        9968  Jan 31 2013 13:23:50 -05:00  xml-test.html
Directory of flash:/phone/
   56  -rw-     2455771  Jan 31 2013 13:24:02 -05:00  apps31.8-2-2TR2.sbn
   57  -rw-       49599  Jan 31 2013 13:24:04 -05:00  S00105000200.sbn
   58  -rw-     2453315  Jan 31 2013 13:24:14 -05:00  apps70.8-2-2TR2.sbn
   59  -rw-      339307  Jan 31 2013 13:24:16 -05:00  CP7905080002SCCP060817A.sbin
   60  -rw-     1155568  Jan 31 2013 13:24:22 -05:00  cmterm_7920.4.0-03-02.bin
   61  -rw-     1763446  Jan 31 2013 13:24:30 -05:00  cmterm_7936.3-3-13-0.bin
   62  -rw-    14997798  Jan 31 2013 13:25:30 -05:00  cmterm_7985.4-1-2-0.bin
   63  -rw-      331693  Jan 31 2013 13:25:32 -05:00  CP7902080002SCCP060817A.sbin
   64  -rw-      129824  Jan 31 2013 13:25:34 -05:00  P00308000500.bin
   65  -rw-      341088  Jan 31 2013 13:25:36 -05:00  CP7912080002SCCP060817A.sbin
   66  -rw-      349794  Jan 31 2013 13:25:38 -05:00  P00405000700.bin
   67  -rw-      439794  Jan 31 2013 13:25:40 -05:00  cnu31.8-2-2TR2.sbn
   68  -rw-     2029545  Jan 31 2013 13:25:50 -05:00  P00503021500.bin
   69  -rw-     2455771  Jan 31 2013 13:26:00 -05:00  apps11.8-2-2TR2.sbn
   70  -rw-      439073  Jan 31 2013 13:26:02 -05:00  cnu11.8-2-2TR2.sbn
   71  -rw-     2146975  Jan 31 2013 13:26:12 -05:00  cvm11sccp.8-2-2TR2.sbn
   72  -rw-      302171  Jan 31 2013 13:26:14 -05:00  dsp11.8-2-2TR2.sbn
   73  -rw-      377390  Jan 31 2013 13:26:16 -05:00  jar11sccp.8-2-2TR2.sbn
   74  -rw-         662  Jan 31 2013 13:26:16 -05:00  SCCP11.8-2-2SR2S.loads
   75  -rw-         662  Jan 31 2013 13:26:18 -05:00  term06.default.loads
   76  -rw-         662  Jan 31 2013 13:26:18 -05:00  term11.default.loads
   77  -rw-     2141829  Jan 31 2013 13:26:28 -05:00  cvm31sccp.8-2-2TR2.sbn
   78  -rw-      302171  Jan 31 2013 13:26:30 -05:00  dsp31.8-2-2TR2.sbn
   79  -rw-      376618  Jan 31 2013 13:26:32 -05:00  jar31sccp.8-2-2TR2.sbn
   80  -rw-         643  Jan 31 2013 13:26:32 -05:00  SCCP31.8-2-2SR2S.loads
   81  -rw-         643  Jan 31 2013 13:26:34 -05:00  term31.default.loads
   82  -rw-     2453315  Jan 31 2013 13:26:44 -05:00  apps41.8-2-2TR2.sbn
   83  -rw-      435144  Jan 31 2013 13:26:46 -05:00  cnu41.8-2-2TR2.sbn
   84  -rw-     2141080  Jan 31 2013 13:26:56 -05:00  cvm41sccp.8-2-2TR2.sbn
   85  -rw-      509329  Jan 31 2013 13:26:58 -05:00  dsp41.8-2-2TR2.sbn
   86  -rw-      229333  Jan 31 2013 13:27:00 -05:00  jar41sccp.8-2-2TR2.sbn
   87  -rw-         642  Jan 31 2013 13:27:02 -05:00  SCCP41.8-2-2SR2S.loads
   88  -rw-         642  Jan 31 2013 13:27:02 -05:00  term41.default.loads
   89  -rw-         642  Jan 31 2013 13:27:04 -05:00  term61.default.loads
   90  -rw-      435605  Jan 31 2013 13:27:06 -05:00  cnu70.8-2-2TR2.sbn
   91  -rw-     2143067  Jan 31 2013 13:27:16 -05:00  cvm70sccp.8-2-2TR2.sbn
   92  -rw-      509329  Jan 31 2013 13:27:18 -05:00  dsp70.8-2-2TR2.sbn
   93  -rw-      474957  Jan 31 2013 13:27:20 -05:00  jar70sccp.8-2-2TR2.sbn
   94  -rw-         642  Jan 31 2013 13:27:22 -05:00  SCCP70.8-2-2SR2S.loads
   95  -rw-         642  Jan 31 2013 13:27:22 -05:00  term70.default.loads
   96  -rw-         642  Jan 31 2013 13:27:22 -05:00  term71.default.loads
   97  -rw-      338891  Jan 31 2013 13:27:26 -05:00  CP7905080002SCCP060817A.zup
   98  -rw-         458  Jan 31 2013 13:27:26 -05:00  P00308000500.loads
   99  -rw-      705536  Jan 31 2013 13:27:30 -05:00  P00308000500.sb2
  100  -rw-      130228  Jan 31 2013 13:27:30 -05:00  P00308000500.sbn
  101  -rw-      350198  Jan 31 2013 13:27:34 -05:00  P00405000700.sbn
Directory of flash:/ringtones/
  103  -rw-        8160  Jan 31 2013 13:27:34 -05:00  Analog1.raw
  104  -rw-        8160  Jan 31 2013 13:27:36 -05:00  Analog2.raw
  105  -rw-        5280  Jan 31 2013 13:27:36 -05:00  AreYouThere.raw
  106  -rw-        5040  Jan 31 2013 13:27:36 -05:00  AreYouThereF.raw
  107  -rw-        8160  Jan 31 2013 13:27:38 -05:00  Bass.raw
  108  -rw-       12240  Jan 31 2013 13:27:38 -05:00  CallBack.raw
  109  -rw-       16040  Jan 31 2013 13:27:38 -05:00  Chime.raw
  110  -rw-        8160  Jan 31 2013 13:27:40 -05:00  Classic1.raw
  111  -rw-       16080  Jan 31 2013 13:27:40 -05:00  Classic2.raw
  112  -rw-       10800  Jan 31 2013 13:27:42 -05:00  ClockShop.raw
  113  -rw-        2823  Jan 31 2013 13:27:42 -05:00  DistinctiveRingList.xml
  114  -rw-        9600  Jan 31 2013 13:27:42 -05:00  Drums1.raw
  115  -rw-       13440  Jan 31 2013 13:27:44 -05:00  Drums2.raw
  116  -rw-       15840  Jan 31 2013 13:27:44 -05:00  FilmScore.raw
  117  -rw-       16080  Jan 31 2013 13:27:46 -05:00  HarpSynth.raw
  118  -rw-        8160  Jan 31 2013 13:27:46 -05:00  Jamaica.raw
  119  -rw-       16080  Jan 31 2013 13:27:48 -05:00  KotoEffect.raw
  120  -rw-       12720  Jan 31 2013 13:27:48 -05:00  MusicBox.raw
  121  -rw-        8160  Jan 31 2013 13:27:48 -05:00  Piano1.raw
  122  -rw-       15360  Jan 31 2013 13:27:50 -05:00  Piano2.raw
  123  -rw-        9360  Jan 31 2013 13:27:50 -05:00  Pop.raw
  124  -rw-        7200  Jan 31 2013 13:27:52 -05:00  Pulse1.raw
  125  -rw-        4000  Jan 31 2013 13:27:52 -05:00  Ring1.raw
  126  -rw-        4000  Jan 31 2013 13:27:52 -05:00  Ring2.raw
  127  -rw-        4000  Jan 31 2013 13:27:54 -05:00  Ring3.raw
  128  -rw-        4000  Jan 31 2013 13:27:54 -05:00  Ring4.raw
  129  -rw-        4000  Jan 31 2013 13:27:56 -05:00  Ring5.raw
  130  -rw-        4000  Jan 31 2013 13:27:56 -05:00  Ring6.raw
  131  -rw-        4000  Jan 31 2013 13:27:56 -05:00  Ring7.raw
  132  -rw-         495  Jan 31 2013 13:27:58 -05:00  RingList.xml
  133  -rw-       10800  Jan 31 2013 13:27:58 -05:00  Sax1.raw
  134  -rw-       14160  Jan 31 2013 13:28:00 -05:00  Sax2.raw
  135  -rw-       16080  Jan 31 2013 13:28:00 -05:00  Vibe.raw
Directory of flash:/its/
  137  -rw-           0   Aug 1 2013 09:29:26 -04:00  SEPDEFAULT.cnf
  138  -rw-        1650   Aug 1 2013 09:29:36 -04:00  XMLDefault.cnf.xml
  139  -rw-         311   Aug 1 2013 09:29:38 -04:00  ATADefault.cnf.xml
  140  -rw-         824   Aug 1 2013 09:29:38 -04:00  XMLDefault7905.cnf.xml
  141  -rw-         424   Aug 1 2013 09:29:38 -04:00  XMLDefault7902.cnf.xml
  142  -rw-         824   Aug 1 2013 09:29:40 -04:00  XMLDefault7920.cnf.xml
  143  -rw-         969   Aug 1 2013 09:29:40 -04:00  XMLDefault7921.cnf.xml
  144  -rw-         404   Aug 1 2013 09:29:40 -04:00  XMLDefault7936.cnf.xml
  145  -rw-        1043   Aug 1 2013 09:29:40 -04:00  XMLDefault7970.cnf.xml
  146  -rw-        1147   Aug 1 2013 09:29:42 -04:00  XMLDefault7970-1.cnf.xml
  147  -rw-        1220   Aug 1 2013 09:29:42 -04:00  XMLDefault7970-2.cnf.xml
  148  -rw-        1043   Aug 1 2013 09:29:44 -04:00  XMLDefault7971.cnf.xml
  149  -rw-        1147   Aug 1 2013 09:29:44 -04:00  XMLDefault7971-1.cnf.xml
  150  -rw-        1220   Aug 1 2013 09:29:44 -04:00  XMLDefault7971-2.cnf.xml
  151  -rw-        1065   Aug 1 2013 09:29:44 -04:00  XMLDefault7961.cnf.xml
  152  -rw-        1169   Aug 1 2013 09:29:46 -04:00  XMLDefault7961-1.cnf.xml
  153  -rw-        1242   Aug 1 2013 09:29:46 -04:00  XMLDefault7961-2.cnf.xml
  154  -rw-        1043   Aug 1 2013 09:29:46 -04:00  XMLDefault7961GE.cnf.xml
  155  -rw-        1147   Aug 1 2013 09:29:48 -04:00  XMLDefault7961GE-1.cnf.xml
  156  -rw-        1220   Aug 1 2013 09:29:48 -04:00  XMLDefault7961GE-2.cnf.xml
  157  -rw-        1043   Aug 1 2013 09:29:48 -04:00  XMLDefault7941.cnf.xml
  158  -rw-        1043   Aug 1 2013 09:29:50 -04:00  XMLDefault7941GE.cnf.xml
  159  -rw-        1043   Aug 1 2013 09:29:50 -04:00  XMLDefault7931.cnf.xml
  160  -rw-        1043   Aug 1 2013 09:29:50 -04:00  XMLDefault7911.cnf.xml
  161  -rw-        1043   Aug 1 2013 09:29:52 -04:00  XMLDefault7906.cnf.xml
  162  -rw-        1043   Aug 1 2013 09:29:52 -04:00  XMLDefault7985.cnf.xml
  163  -rw-         824   Aug 1 2013 09:29:52 -04:00  XMLDefault7912.cnf.xml
  164  -rw-         510   Aug 1 2013 09:29:52 -04:00  XMLDefault7910.cnf.xml
  165  -rw-         404   Aug 1 2013 09:29:54 -04:00  XMLDefault7935.cnf.xml
  166  -rw-         919   Aug 1 2013 09:29:54 -04:00  XMLDefault7960.cnf.xml
  167  -rw-        1023   Aug 1 2013 09:29:54 -04:00  XMLDefault-1.cnf.xml
  168  -rw-        1096   Aug 1 2013 09:29:56 -04:00  XMLDefault-2.cnf.xml
  169  -rw-        1007   Aug 1 2013 09:29:56 -04:00  XMLDefaultCIPC.cnf.xml
  176  -rw-         903   Aug 1 2013 09:30:00 -04:00  united_states_7960-tones.xml
  177  -rw-        8777   Aug 1 2013 09:30:00 -04:00  united_states_7960-font.xml
  178  -rw-        1313   Aug 1 2013 09:30:02 -04:00  united_states_7960-kate.xml
  179  -rw-       19750   Aug 1 2013 09:30:02 -04:00  united_states_7960-dictionary.xml
  180  -rw-        2711   Aug 1 2013 09:30:02 -04:00  united_states_SCCP-dictionary.xml
  170  -rw-      221560  Jul 29 2013 14:10:10 -04:00  crashinfo_20130729-181010
  171  -rw-      176780  Jul 29 2013 14:17:12 -04:00  crashinfo_20130729-181713
  172  -rw-      182636  Jul 30 2013 09:09:54 -04:00  crashinfo_20130730-130955
2811#
It is weird, because on July 27th, the IOS was there, I kept an old print-out:
2811#
2811#sh flash
-#- --length-- -----date/time------ path
1     45182188 Jan 31 2013 13:16:50 -05:00 c2800nm-adventerprisek9-mz.124-11.XJ4.bin
2811#
2811#sh flash
John,
I am scratching my head. Hmmm... Would you mind running fsck flash: command and see if any errors are reported or corrected?
Best regards,
Peter
2811#fsck flash:
Checking the partition table and boot sector...
Checking FAT, Files and Directories...
Reclaiming unused space...
Updating FAT...
fsck of flash: complete
2811#
Nothing....
there must be a way to "repair" thatt flash.... In fact, the reason I need to see it is because I want to delete it to upgrade to a newer version that allows Network Object Groups...(c2800nm-adventerprisek9-mz.124-20.YA2.bin does).
But if it can't see it, it can't delete it.
Where can I see the boot image it uses upon booting ?  Can I do a display of
boot system flash:c2800nm-adventerprisek9-mz.124-11.XJ4.bin ?????
To see under what flash directory it is located ? I know it's there, somewhere.....
John,
I wonder - do you have a CF card reader somewhere around? With any luck, the CF card is formatted with FAT filesystem so it should be plain simple to check its contents under Windows or Linux.
Best regards,
Peter
Yes, verified with a compact flash reader, all the files are there as per the dir flash:, but no IOS.
The IOS must be there because when I add the 59 MB on the compact flash card + the 23 MB left on it, I am missing 45MB to total the 128MB capacity....
45 MB is the size of the IOS....
how about
show bootvar
res
paul
Sent from Cisco Technical Support Android App
Kind Regards
Paul
That command does not exist on my router.
I got nothing that start by show b in privilege mode 15
