IOS PAT + VPN configuration
acomiskey
Level 10
Level 10
A server (10.0.0.5) is accessible from the outside on ports 443 and 3389.
ip nat inside source static tcp 10.0.0.5 443 interface FastEthernet0/0 443
ip nat inside source static tcp 10.0.0.5 3389 interface FastEthernet0/0 3389
I also need to access 10.0.0.5 while connected to a remote access vpn. Here is my configuration for nat and nat exemption. (192.168.50.0/24 is the vpn subnet)
ip nat inside source route-map nonat interface FastEthernet0/0 overload
access-list 111 deny   ip 10.0.0.0 0.0.0.255 192.168.50.0 0.0.0.255
access-list 111 permit ip 10.0.0.0 0.0.0.255 any
access-list 111 permit ip 192.168.1.0 0.0.0.255 any
route-map nonat permit 10
match ip address 111
I can access 10.0.0.5 on 443 and 3389 from the outside as planned using the address of fa0/0, but I cannot access 10.0.0.5 while vpn'd. I'm sure it has something to do with the nat configuration but can't find a solution.
acomiskey
Level 10
Level 10
Bump....
