IOS Problem
arjunsawant
I have Cisco 2509 Router with 8 MB Flash and ios is c2500-i-l.120-3.T.bin.
I am not able to configure Netflow on my router.Some command like ,
ip flow-export source FastEthernet 0/1,
ip flow-export version 5,
p flow-cache timeout active 1,
ip flow-cache timeout inactive 15,
snmp-server ifindex persist
are not accepted.
Please suggest me which IOS is support for this.It's urgent.....Thanks.
6 Replies 6
bjornarsb
Level 4
Level 4
Hi, buy a new 2800 router.
Bjornarsb
Is there any IOS which is supporting to Cisco 2500 router with 8MB flash.
12.1(27b)
c2500-i-l.12.1-27b
http://www.cisco.com/cgi-bin/Software/SWSearch/SWSearch_results.cgi/SWSearch.txt?isChild=true&dir_delimiter=contains&dir_pattern=&file_delimiter=contains&file_pattern=c2500-i-l.121-27b+&list_format=html
try this one..
and ip flow* should work on this too as it was introdused in 11.1
hope that helps..
plz rate..
Thanks a lot....
a Vote / Rate would be appreciated :-)
