IOS Remote Access VPN (AnyConnect) Troubleshooting
corycandia
Experts,
I am looking for some assistance with configuring/troubleshooting IOS to do AnyConnect remote access, allowing remote users to access local resources, as well as traverse other L2L tunnels on the 1921.
What is not working:
I am not able to get remote users connected to the hub 1921 via AnyConnect to be able to access internal resources, or resources over a L2L tunnel to an ASA5520.
What is working:
  • Internal hosts on the 1921 can access internet hosts, and hosts on the other end of the L2L tunnel with an ASA5520.  From what I can tell, the L2L tunnel with the ASA is fine.
  • Remote access hosts can ping/access the 1921 (loopback interface).
What I believe is correct:
  • I believe crypto-map ACLs and NAT statements are correct on both sides.  (Also, internal hosts on the 1921 can access resources over the tunnel)
Possible issues:
  1. Zone based firewall not configured correctly?
    • Do remote hosts (172.20.52.0/29) need a zone pair from outside to inside?
      • How would you mark the other policy based tunnels as inside if so?
    • What debug command would show me if firewall rules are blocking 172.20.52.0/29 hosts from going to 172.20.48.0/24 or 192.168.0.0/24 hosts?
  2. Webvpn context missing something?
    • I've tried adding an ACL here like some examples have shown, it didn't work.
  3. Virtual Interface config?
    • I'm not very familiar with the 'interface virtual-template' config the cisco guides dictated
    • I added it as an inside zone member trying to troubleshoot firewall issues.
I can't find anymore configuration examples to follow for this.
This was the guide I used to get this partially setup: https://www.cisco.com/c/en/us/support/docs/security/anyconnect-secure-mobility-client/200533-AnyConnect-Configure-Basic-SSLVPN-for-I.html#anc13
Lastly, this router is a hub for other ASAs to dynamically connect to.  Since the ASA5500 series doesn't do VTIs, I had to create a policy based dynamic map on this 1921 to avoid creating a bunch of individual L2Ls.  It works, I've already tested that a 5505 could connect and traffic flowed.  I kept the ASA5520 being used for this testing static for more clarity.
Can anyone offer more guidance?
Our topology:
Spoiler
TopologyTopology
Config:
Spoiler
Cisco 2941 HUB Router
Current configuration : 21224 bytes
! Last configuration change at 10:03:23 EDT Fri May 10 2019 by [REDACTED]
version 15.7
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname [REDACTED]
boot-start-marker
boot system flash:c1900-universalk9-mz.SPA.157-3.M3.bin
boot system flash:c1900-universalk9-mz.SPA.154-3.M2.bin
boot-end-marker
logging buffered 4096
enable secret 5 [REDACTED]
aaa new-model
aaa authentication login default local
aaa authentication login local_access local
aaa authentication login AAA_ANYCONNECT local
aaa authorization exec default local
aaa session-id common
clock timezone EST -5 0
clock summer-time EDT recurring
ip dhcp pool DHCP-POOL_INTERNAL
 network 172.20.48.0 255.255.255.0
 domain-name [REDACTED]
 default-router 172.20.48.254
 dns-server 192.168.0.1 172.20.0.6 8.8.8.8
no ip bootp server
ip domain lookup source-interface GigabitEthernet0/0
ip domain name [REDACTED]
ip name-server 192.168.0.1
ip name-server 192.168.0.2
ip name-server 172.20.0.6
ip cef
no ipv6 cef
flow record nbar-appmon
 match ipv4 source address
 match ipv4 destination address
 match application name
 collect interface output
 collect counter bytes
 collect counter packets
 collect timestamp absolute first
 collect timestamp absolute last
flow monitor application-mon
 cache timeout active 60
 record nbar-appmon
parameter-map type inspect global
 max-incomplete low 18000
 max-incomplete high 20000
 nbar-classify
cts logging verbose
crypto pki trustpoint selfsigned
 enrollment selfsigned
 revocation-check crl
crypto pki trustpoint test_trustpoint_config_created_for_sdm
 subject-name e=sdmtest@sdmtest.com
crypto pki trustpoint [REDACTED]
 enrollment terminal
 usage ike
 usage ssl-server
 usage ssl-client
 fqdn [REDACTED]
 subject-name [REDACTED]
crypto pki certificate chain selfsigned
crypto pki certificate chain test_trustpoint_config_created_for_sdm
crypto pki certificate chain [REDACTED]
 certificate [REDACTED]
        quit
 certificate ca [REDACTED]
        quit
license udi pid CISCO1921/K9 sn [REDACTED]
redundancy
crypto ikev2 proposal IKEV2-PROPOSAL_1
 encryption aes-cbc-256
 integrity sha512
 group 24
crypto ikev2 proposal IKEV2-PROPOSAL_2
 integrity sha256
 group 24
crypto ikev2 policy IKEV2-POLICY
crypto ikev2 profile IKEV2-PROFILE_S2S_ASA5520
 match identity remote address [REDACTED]
 identity local key-id ASA5520
 authentication remote pre-share key [REDACTED]
 authentication local pre-share key [REDACTED]
crypto ikev2 profile IKEV2-PROFILE_S2S_DYNAMIC
 description ** Allows dynamic tunnels **
 match identity remote any
no crypto ikev2 http-url cert
class-map match-any CM_VOICE
 match ip dscp ef
class-map type inspect match-any INTERNAL_DOMAIN_FILTER
 match protocol msnmsgr
 match protocol ymsgr
class-map type inspect match-all CLASSMAP_INSPECTION-VPN-IN
 match access-group name ACL_VPN-IN
class-map type inspect match-any CLASSMAP_INSPECTION-OUTBOUND
 match protocol tcp
 match protocol udp
 match protocol icmp
 match protocol dns
 match protocol http
 match protocol https
policy-map type inspect POLICYMAP_INSPECTION-OUTBOUND
 class type inspect CLASSMAP_INSPECTION-OUTBOUND
  inspect
 class class-default
  drop log
policy-map PM_QOS
 class CM_VOICE
  priority
 class class-default
  fair-queue
policy-map PM_OUTSIDE_OUTBOUND
 class class-default
  shape average 12000000
   service-policy PM_QOS
policy-map type inspect POLICYMAP_INSPECTION-VPN-IN
 class type inspect CLASSMAP_INSPECTION-VPN-IN
  inspect
 class class-default
  drop
zone security INTERNET
zone security INSIDE
zone-pair security ZP_INSIDE-to-OUTSIDE source INSIDE destination INTERNET
 service-policy type inspect POLICYMAP_INSPECTION-OUTBOUND
zone-pair security ZP_OUTSIDE-to-INSIDE source INTERNET destination INSIDE
crypto vpn anyconnect usbflash0:/webvpn/anyconnect-win-4.4.00243-webdeploy-k9.pkg sequence 1
crypto isakmp policy 1
crypto isakmp policy 2
 encr aes 256
 hash sha256
 group 2
crypto ipsec transform-set TRANSFORMSET-IPSEC_S2S-ASA esp-aes 256 esp-sha-hmac
 mode tunnel
crypto ipsec transform-set TRANSFORMSET-IPSEC_S2S-DYNAMIC esp-aes 256 esp-sha-hmac
 mode tunnel
crypto dynamic-map CRYPTOMAP-DYNAMIC_S2S-DYNAMIC 1
 description ** DYNAMIC TUNNELS **
 set transform-set TRANSFORMSET-IPSEC_S2S-DYNAMIC
 set pfs group24
 set ikev2-profile IKEV2-PROFILE_S2S_DYNAMIC
crypto map CRYPTOMAP_OUTSITE 1 ipsec-isakmp
 set peer [REDACTED]
 set transform-set TRANSFORMSET-IPSEC_S2S-ASA
 set pfs group24
 set ikev2-profile IKEV2-PROFILE_S2S_ASA5520
 match address ACL_CRYPTOMAP-S2S-ASA
crypto map CRYPTOMAP_OUTSITE 65001 ipsec-isakmp dynamic CRYPTOMAP-DYNAMIC_S2S-DYNAMIC
interface Loopback0
 ip address 172.20.55.254 255.255.255.255
interface Embedded-Service-Engine0/0
 no ip address
 shutdown
 description **Inside Interface**
 mtu 1400
 ip address 172.20.48.254 255.255.255.0
 ip nat inside
 ip virtual-reassembly in
 zone-member security INSIDE
 duplex auto
 speed auto
interface GigabitEthernet0/1
 description ** OUTSIDE INTERNET **
 ip address dhcp
 no ip proxy-arp
 ip nat outside
 zone-member security INTERNET
 duplex auto
 speed auto
 no cdp enable
interface Virtual-Template1
 ip unnumbered Loopback0
ip local pool ADDRESSPOOL_ANYCONNECT 172.20.52.1 172.20.52.6
ip forward-protocol nd
ip http server
ip http upload enable path flash:
ip http upload overwrite
ip http access-class 23
ip http authentication local
ip http secure-server
ip http secure-trustpoint [REDACTED]
ip tftp source-interface Loopback0
ip nat inside source route-map ROUTEMAP_NAT interface GigabitEthernet0/1 overload
ip route 0.0.0.0 0.0.0.0 dhcp
ip ssh source-interface GigabitEthernet0/0
ip ssh version 2
ip scp server enable
ip access-list standard ACL_ANYCONNECT-SPLITTUNNEL
 permit 172.20.0.0 0.0.63.255
 permit 10.1.0.0 0.0.7.255
 permit 192.168.0.0 0.0.7.255
ip access-list extended ACL_CRYPTOMAP-S2S-ASA
 permit ip 172.20.48.0 0.0.7.255 192.168.0.0 0.0.7.255
 permit ip 172.20.48.0 0.0.7.255 10.1.0.0 0.0.7.255
 permit ip 172.20.48.0 0.0.7.255 172.20.32.0 0.0.7.255
ip access-list extended ACL_NAT
 deny   ip 172.20.48.0 0.0.7.255 172.20.0.0 0.0.63.255
 deny   ip 172.20.48.0 0.0.7.255 192.168.0.0 0.0.7.255
 deny   ip 172.20.48.0 0.0.7.255 10.1.0.0 0.0.7.255
 permit ip 172.20.48.0 0.0.0.255 any
ip access-list extended ACL_VPN-IN
 permit esp any any
 permit udp any any eq isakmp
route-map ROUTEMAP_NAT permit 10
 match ip address ACL_NAT
 match interface GigabitEthernet0/1
access-list 23 permit 172.20.0.0 0.0.63.255
access-list 23 permit 192.168.0.0 0.0.7.255
access-list 23 permit 10.1.0.0 0.0.7.255
control-plane
 vstack
line con 0
 session-timeout 60
 exec-timeout 60 0
 session-disconnect-warning 300
 logging synchronous
 login authentication local_access
line aux 0
line 2
 no activation-character
 no exec
 transport preferred none
 transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
 stopbits 1
line vty 0 4
 session-timeout 60
 access-class 23 in
 exec-timeout 60 0
 privilege level 15
 logging synchronous
 transport input telnet ssh
line vty 5 15
 session-timeout 60
 logging synchronous
 transport input none
scheduler allocate 20000 1000
ntp server 192.168.3.5 source GigabitEthernet0/0
webvpn gateway WEBVPN-GATEWAY_ANYCONNECT
 ip interface GigabitEthernet0/1 port 1025
 ssl trustpoint [REDACTED]
 inservice
 dtls port 1025
webvpn context WEBVPN-CONTEXT_ANYCONNECT
 aaa authentication list AAA_ANYCONNECT
 ssl authenticate verify all
 inservice
 policy group GROUPPOLICY_ANYCONNECT-SPLIT
   functions svc-enabled
   svc address-pool "ADDRESSPOOL_ANYCONNECT" netmask 255.255.255.248
   svc keep-client-installed
   svc split include acl ACL_ANYCONNECT-SPLITTUNNEL
   svc dns-server primary 192.168.0.1
   svc dns-server secondary 192.168.0.2
 policy group GROUPPOLICY-ANYCONNECT-FULL
 default-group-policy GROUPPOLICY_ANYCONNECT-SPLIT
end
the subnet you included in the ACL, 172.20.52.0/18, includes all hosts in the range 172.20.0.1 - 172.20.63.254, which includes the entire inside network.
To be on the safe side, and to avoid making mistakes with access lists, I would always use an IP address range that is completely different from the local LAN (your NAT inside). So instead of 172.120.x.x, use something in the 10.x.x.x or 192.168.x.x range for the address pools...
5 Replies 5
your local address pool (172.20.52.1 172.20.52.6) and your inside network appear to be in the same subnet that is included in the split ACL. Try to make the changes in bold:
permit 172.20.52.0 0.0.0.255
inservice
svc address-pool "ADDRESSPOOL_ANYCONNECT" netmask 255.255.255.0
virtual-template 1
Georg,
Thanks for reviewing my issue.
I believe the inside network should be 172.20.48.0/24.
 mtu 1400
 ip nat inside
 duplex auto
 speed auto
There are four other sites (each site is assigned a /20) which is why I used a /18 in the split tunnel ACL.
I could break that out and only include the blocks for the other sites and the local block (172.20.48.0/24) if you think that should be tested.
Am I missing something else?
I'll start testing those changes once I get back to the device.
Here's something else that's weird:
The remote client can ping the 1921's loopback interface (Loopback 0, 172.20.55.254), which is included in the current split tunnel ACL
 permit 172.20.0.0 0.0.63.255 (loopback is in here, works)
 permit 192.168.0.0 0.0.7.255 (doesn't work)
Remote clients can ping this guy:
interface Loopback0
@Georg Pauwen wrote:
...To be on the safe side, and to avoid making mistakes with access lists, I would always use an IP address range that is completely different from the local LAN (your NAT inside)...
I think that was the key.  I didn't change the subnet I was using, but I changed the NAT ACL based on what you said about not overlapping:
 deny   ip 172.20.48.0 0.0.3.255 172.20.55.0 0.0.0.7 (added for AnyConnect)
 deny   ip 172.20.48.0 0.0.7.255 172.20.0.0 0.0.63.255 (Sites 1-4 including this one)
 deny   ip 172.20.48.0 0.0.7.255 192.168.0.0 0.0.7.255 (5th site)
 deny   ip 172.20.48.0 0.0.7.255 10.1.0.0 0.0.7.255 (6th site)
(The remote subnet doesn't actually overlap the local LAN, local LAN is a /24 and remote is a /29 in two different subnets, but do the site to site tunnels using blocks /21 so one statement covers all the subnets at that site)
Results from remote AnyConnect client on 172.20.52.0/29:
Hitting other sites while remoted in using AnyConnect 172.20.52.2 going to:
