ios selection by features
alewirvie
I would to know if have any tool where i paste running-config and based on commands the tool generate a list of features that configuration use and, maybe, versions of ios that support this feature.
example: one running config with some tacacs+, cef and dsl support.
1. i will post running config about that configuration
2. the tool tell me what features is necessary to configure that lines
3. the tool give me options that include the minimum ios that support that and all other avaliable options
maybe we put hardware plataform to.
if isnt exist, is a sugestion to a tool
other question
exist one tool that tell me what configuration lines every feature give me in console? or the oposite... i put the lines and the tool tell me the features.
example:
tacacs+
aaa ??options??
aaa ??options??
aaa ??options??
thank you for your patient!
my english isnt good! sory for that!
regards
wirz
5 Replies 5
Edison Ortiz
There is a tool already, it's called Software Advisor
http://tools.cisco.com/Support/Fusion/FusionHome.do
thanks you Edison!
thank for your patience!
I know software advisor.
Perhaps I don?t have expressed correctly!
a simple example of an situation:
i need use one cisco 805 and have these lines in running-config:
aaa authentication login default group tacacs+ local
aaa authorization exec default group tacacs+ local
aaa authorization commands 0 default group tacacs+ none
aaa authorization commands 1 default group tacacs+ none
aaa authorization commands 15 default group tacacs+ none
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 0 default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group tacacs+
in ios specs or sotware advisor show me the follow features:
aaa broadcast accouting
aaa DNIS map for authorization
aaa server group
aaa server group enchancements
aaa server group based on DNIS
how i discover what features is needed in an ios to this configuration??
what command lines are incresed by any feature?
i need make this a lot of times per day.
many times instal an ios and paste all the comands to ensure that all commands will be aplicated sucessfully
Within Software Advisor, you can select 'AAA' as a feature and it will recommend an IOS for download that should support your router.
You don't need to do multiple times a day, just once.
I guess I don't understand your question ....
hi,
Please use Cisco Feature Navigator:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
Search by feature (there is a description for each feature, use the "show description" button) and more over select your platform to get the exact IOS for your platform that supports your required features.
P.S The simple AAA commands you are using are supported on all platforms in all IOS, if you require any advanced AAA feature then search in the feature navigator.
HTH,
Mohammed Mahmoud.
EPHRAIM MANI
Level 3
Level 3
I would suggest gather the specific feature u require and visit the Software Advisory section of Cisco url provided mohammedmahmoud above.
Kindly rate all the posts if its helpful.
Thanks EM
