IOS Suggestion required 3945
lenins.akm
HI,
I have got a Cisco 3945 router. I would like to know which IOS image I can use?
It should provide me
BGP
HSRP
TUNNELs
SLAs
ACLs
ENCRYPTION
and it should be
bug free.
Please suggest an image.
Sonal Singh
The Cisco ISR 1900, 2900 and 3900 Series adopt the Universal IOS image model so you have enable license for the features.
According to the features specififed above you will need: IP base,Data and Security license.
As far stability is concern the latest IOS for the device is 151-4.M1 which contain maximum number of bug fixes and is most relaible.
Here is the link to download IOS for the device:
http://www.cisco.com/cisco/software/release.html?mdfid=282774228&flowid=7442&softwareid=280805680&release=15.1.4M1&rellifecycle=ED&relind=AVAILABLE&reltype=latest
To know which license you should enable on the device for the features you can refer to the document:
http://www.cisco.com/en/US/prod/collateral/routers/ps10616/white_paper_c11_556985_ps10537_Products_White_Paper.html#wp9000809
Hope this help:)
Sonal
