IOS support for SSH Server on 1603 routers
m.tapping
Is there any IOS support for SSH Server on 1603 routers? I cannot find anything when using the Feature Navigator.
Thanks.
Marc.T
spremkumar
Level 9
Level 9
hi
you need to have ip plus ipsec or ip fw plus ipsec feature set to have SSH terminal line access.
i did give try and found c1600-k8sy-l.12.2-15.T17 suits that but if u need some other feature then would suggest to check out for a suitable code.
regds
Thanks for the reply.
I believe what I need is SSH Server on a 1600 platform so that I can secure communications to the VTY ports. I do not require console or async ports to be secured via SSH which I think SSH terminal line access gives me.
I've been unable to find any IOS that provides this.
Marc.T
