IOS to XE convertor tool Output question
jwornstaff
So I'm attempting to use the IOS to XE convertor tool, and having difficult time understanding the output results and why some lines are showing "Unprocessed" . I have like 191 lines showing "unprocessed" with pretty basic commands, that don't make sense to me, what is it trying to tell me.
Example:
Unchanged tunnel interface commands
  • 335 interface Tunnel371
  • description Tunnel 371 (via DS3) to SP7NRTR01 (10.0.2.46)
  • ip address 10.0.x.x 255.255.255.252
  • ip mtu 1399
  • ------------------------- Then remaining tunnel config show unprocessed...why?
  • !ip wccp password xxxxxxxxx
  • !ip hold-time eigrp 10 45
  • !ip flow ingress
  • !ip tcp adjust-mss 1359
  • !load-interval 30
  • !delay 1000
  • !qos pre-classify
  • !keepalive 10 3
  • !cdp enable
  • !tunnel source 10.0.x.x
  • !tunnel destination 10.0.x.x
  • !tunnel path-mtu-discovery
Other notable lines indicating "unprocessed"
vlan 30
ip vrf xx
rd 1:1
standby 1
connection plar 2221111
privilege exec level
crypto map
lespejel
Level 3
Level 3
Hello @jwornstaff
I think it's trying to tell you what commands are not supported or outdated.
  •  !ip flow ingress -------  this is old netflow, you should use flexible netflow not
vlan 30
ip vrf xx ******* now vrf forwarding name
rd 1:1
standby 1 check config guide for HSRP
crypto map not sure is this is still a good pratice.
CCIE 52804
