IOS upgradation in Cisco 7609
kumar94437
Sir,
I want to grade my cisco 7609 router.
CENTRAL#sh ver
IOS (tm) s72033_rp Software (s72033_rp-JK9O3SV-M), Version 12.2(17a)SX4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Wed 21-Apr-04 23:46 by pwade
Image text-base: 0x40008FBC, data-base: 0x4223A000
ROM: System Bootstrap, Version 12.2(17r)S2, RELEASE SOFTWARE (fc1)
BOOTLDR: s72033_rp Software (s72033_rp-JK9O3SV-M), Version 12.2(17a)SX4, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
CENTRAL uptime is 1 year, 20 weeks, 1 day, 19 hours, 20 minutes
Time since TRICHYCENTRAL switched to active is 1 year, 20 weeks, 1 day, 19 hours, 19 minutes
System returned to ROM by bus error at PC 0x4165EAB4, address 0x4C at 10:21:11 GMT Sat Oct 18 2008 (SP by power-on)
System restarted at 17:05:28 GMT Sat Oct 18 2008
System image file is "sup-bootflash:s72033-jk9o3sv-mz.122-17a.SX4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco CISCO7609 (R7000) processor (revision 1.1) with 458752K/65536K bytes of memory.
Processor board ID FOX0845006A
SR71000 CPU at 600Mhz, Implementation 0x504, Rev 1.2, 512KB L2 Cache
Last reset from power-on
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
Channelized E1, Version 1.0.
5 FlexWAN controllers (56 E1)(3 Channelized E3).
2 Virtual Ethernet/IEEE 802.3  interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
4 Gigabit Ethernet/IEEE 802.3 interface(s)
66 Serial network interface(s)
3 Channelized E3 port(s)
1917K bytes of non-volatile configuration memory.
8192K bytes of packet buffer memory.
65536K bytes of Flash internal SIMM (Sector size 512K).
Standby is up
Standby has 458752K/65536K bytes of memory.
How to check whether sufficient memory available?.
If i upgrade new IOS can support all the interfaces in my router.
Senthil
8 Replies 8
Giuseppe Larosa
Hello Senthil,
you should also provide the sh module
there are IOS images that support services modules like FWSM, ACE, CSM, WISM and WAN modules like flexwan and other that cannot.
A good recent train with support for service modules is 12.2(33)SXI2a
see this example:
sh module
Mod Ports Card Type                              Model              Serial No.
  2    6  Firewall Module                        WS-SVC-FWM-1       SAD085008DY
  3    8  8 port 1000mb ethernet                 WS-X6408-GBIC      SAD03295602
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAD0851097J
  6   16  CEF720 16 port 10GE                    WS-X6716-10GE      SAL1328TULH
  7   16  SFM-capable 16 port 10/100/1000mb RJ45 WS-X6516-GE-TX     SAL08311CYB
  9    1  Application Control Engine Module      ACE20-MOD-K9       SAD1112028E
Mod MAC addresses                       Hw    Fw           Sw           Status
  2  0012.7ff6.4790 to 0012.7ff6.4797   3.0   7.2(1)       2.3(2)4      Ok
  3  00d0.d39b.7210 to 00d0.d39b.7217   2.3   4.2(0.24)VAI 12.2(33)SXI2 Ok
  5  0011.21a1.6768 to 0011.21a1.676b   4.1   8.1(3)       12.2(33)SXI2 Ok
  6  0024.c463.cd20 to 0024.c463.cd2f   1.0   12.2(18r)S1  12.2(33)SXI2 Ok
  7  0011.9380.62e0 to 0011.9380.62ef   2.6   6.3(1)       12.2(33)SXI2 Ok
  9  001b.2a4e.7b36 to 001b.2a4e.7b3d   2.1   8.7(0.22)ACE A2(1.5a)     Ok
or a 12.2(33)SRE to stay on the C7609 product line
you have 512 MB of RAM on your system, dir /all can tell you the flash size
you have only 64MB of memory for flash
you probably need to put an external flash of bigger size, if possible, to load recent IOS images
dir /all
Directory of disk0:/
    1  -rw-    80679972  Jan 24 2008 20:53:12 +01:00  s72033-advipservicesk9_wan-mz.122-18.SXF11.bin
    2  -rw-   101534052   Oct 8 2009 12:21:58 +02:00  s72033-advipservicesk9_wan-mz.122-33.SXI2a.bin
Hope to help
Giuseppe
Dear sir,
Sh Module output is
  1    0  2 port adapter FlexWAN                 WS-X6182-2PA       JAB090601T4
  2    0  2 port adapter FlexWAN                 WS-X6182-2PA       JAB09060223
  3    0  2 port adapter FlexWAN                 WS-X6182-2PA       JAB085202ZF
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-BASE     SAD08490ELZ
  6    2  Supervisor Engine 720 (Warm)           WS-SUP720-BASE     SAD09050DFM
  7    0  2 port adapter FlexWAN                 WS-X6182-2PA       JAB084703KK
  8   48  48-port 10/100 mb RJ45                 WS-X6148-RJ-45     SAL08424WDU
  9    0  2 port adapter FlexWAN                 WS-X6182-2PA       JAE0922DW04
  1  0011.9304.05b0 to 0011.9304.05ef   1.6   12.2(17a)SX4 12.2(17a)SX4 Ok
  2  0011.9242.a9a0 to 0011.9242.a9df   1.6   12.2(17a)SX4 12.2(17a)SX4 Ok
  3  0012.43de.04c0 to 0012.43de.04ff   1.6   12.2(17a)SX4 12.2(17a)SX4 Ok
  5  000d.ed92.aa30 to 000d.ed92.aa33   3.2   8.1(3)       12.2(17a)SX4 Ok
  6 0011.21ba.c36c to 0011.21ba.c36f   3.2   8.1(3)       12.2(17a)SX4 Ok
  7  0012.00dc.63c0 to 0012.00dc.63ff   1.6   12.2(17a)SX4 12.2(17a)SX4 Ok
  8  0012.800f.2c38 to 0012.800f.2c67   3.1   5.4(2)       8.2(0.56)TET Ok
  9  0014.6955.1540 to 0014.6955.157f   1.6   12.2(17a)SX4 12.2(17a)SX4 Ok
dir /all
    1  -rw-    48404016   Mar 7 2006 06:48:42 +00:05  s72033-jk9o3sv-mz.122-18.SXD2.bin
127848448 bytes total (79441920 bytes free)
I have another router cisco 7609 with the details
Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRC4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 12-May-09 03:11 by prod_rel_team
ROM: System Bootstrap, Version 12.2(17r)SX5, RELEASE SOFTWARE (fc1)
7609-RTR1-CDMA uptime is 10 weeks, 6 days, 14 hours, 41 minutes
Uptime for this control processor is 10 weeks, 6 days, 14 hours, 40 minutes
System returned to ROM by  power cycle at 13:33:22 PDT Wed Sep 23 2009 (SP by power on)
System restarted at 19:47:45 UTC Wed Dec 23 2009
System image file is "bootdisk:c7600s72033-advipservicesk9-mz.122-33.SRC4.bin"
Last reload type: Normal Reload.
Shall I download IOS and use that IOS in old cisco router disk instead of flash.Any problem will come.
Thanks and Regards,
Senthil
Hello Senthil,
with your hardware the SW advisor suggests the following image:
12.2(18)SXF16
s72033-advipservicesk9_wan-mz.12.2-18.SXF16
probably 12.2(33)SXH or 12.2(33)SXI don't support flexwan modules WS-X6182-2PA.
As far as I know the image can be placed on the external disk.
you willl need to configure the correct image name and path
boot system drivename:imagename
Hope to help
Giuseppe
sir,
can i use Cisco IOS Software, c7600s72033_rp Software (c7600s72033_rp-ADVIPSERVICESK9-M), Version 12.2(33)SRC1, RELEASE SOFTWARE (fc1)
This is available in another cisco 7609 router.Whether it will detect Flewan Module
Thanks and Regards,
Senthil
sir,
This is available in  another cisco 7609 router.Whether it will detect Flewan Module.also whether this OS will support ip sla monitor command.
Thanks  and Regards,
Senthil
Hello Senthil,
I think you are probably tied to 12.2(18)SXF with flexwan module as I've seen in SW advisor tool
Hope to help
Giuseppe
Sir,
i want to upgrade this router for using track based routing.Whether this will support ip sla monitor or rtr command.
Thanks and Regards,
Senthil
Hello Senthil,
I've checked on release notes because it looked like strange flexwan modules not supported in recent IOS images.
http://www.cisco.com/en/US/docs/routers/7600/Hardware/12.2SR_supported_hw/DRAFTS/7600_hwd_SRE.html#wp1036417
flexwan service modules are still supported on newer images starting form 12.2(33)SRA
You have probably done this test, the image in your other device should be fine for the upgrade and it should support all those flexwan that are installed.
IP SLA for HSRP, GLBP and VRRP  should be supported but you need IP services, or advanced IP services or advanced enterprise feature set
Edit:
yes, this is fine for your needs
Hope to help
Giuseppe
