01-17-2009 08:25 PM - edited 03-04-2019 12:53 AM
iupgraded the IOS of my office 2800 series router and the out put of sh flash is as below,
CompactFlash directory:
File Length Name/status
1 52234416 ?
Could any tell why ? mark is appraing in name/status column.Router seems working normally.
01-18-2009 05:44 AM
You lost the original filename for some reason. You can use the rename command to fix it. IOS doesn't need a correct filename to work correctly.
Note, 'upgradation' in english is 'upgrade'.
01-18-2009 07:35 AM
Suspected the same. help me in renameming the file name.
01-18-2009 05:45 AM
Hello Raahi,
verify from sh ver output the exact location of the current running image
Example:
sh ver
System restarted at 06:26:19 MET Fri Oct 3 2008
System image file is "flash:c2800nm-adventerprisek9-mz.124-7a.bin"
a question mark may mean a deleted file so take care if you see that the file used to boot is now missing you may need to download it again
Hope to help
Giuseppe
01-18-2009 05:51 AM
Giuseppe, I think the ISR filesystem don't support deleted files as "?" like the older filesystem with squeeze. My theory is that the OP managed to enter ? as a filename hitting the quoting key before question mark during the copy process.
01-18-2009 07:31 AM
sh ver shows the uploaded ios file name.
01-18-2009 08:17 AM
Would be interesting to know how you manage to create the file as the versions that I have prevents use of ? in filenames.
