ios upgrade on cisco 2960 switch
Srinivas N
hi friends,
I have a cisco catalyst 2060 poe switch,
exitsting flas is flash:/c2960-lanbasek9-mz.122-50.SE5/c2960-lanbasek9-mz.122-50.SE5.bin
I downloaded latest flash (c2960-lanbasek9-mz.150-1.SE.bin) and updated the new flas through telnet while reunning tftp server.
and tftp server is given the message sent 2960-lanbsek9-mz,SE.bin to (10.10.10.1), 11847957 bytes
after reload the system i login telnet and saw the verson still it is showing old verson, then how can i comform flash is up-dated or not....
plz find the attached file and help me out.
DETAILS
my tftp server ip is:     10.10.10.10
switch ip is:               10.10.10.1
Thanks & Regards,
Srinivas.
Angus Bishop
HI Srinivas ,
Please see the Show Flash: command for viewing all the images on the device .
Verify the boot variable  to see the sequence of the image .
Angus
8 Replies 8
Angus Bishop
HI Srinivas ,
Angus
yes Anqus your correct and thank u very much your support
i found both images in sh flash command,
But how to conform the switch is running with which image and if it is running with old image
plz let me know how to change for new one and can i delite old flash?
Thanks & Regards,
Srinivas.
Stay away from the 15.0(1)SE and SE1.  It's got a memory leak issue and Cisco is still trying to fix this.
sh ver displays currently running version.
Look for commands in sh run that start with boot. There may be a specific version listed. Delete that line and reboot.
Hi Anqus,
Thanks u very much for your support.
finally i could update the ios image and changed the system boot. now i can see latest image verson.
plz tel me upgradeing ios.. is there any fetures will be added like security and all...
and one more thing i have more than 20 cisco switches..is there any posible to do online upgrade of ios image....
some of the switchs are haveig public IPs and some of them have local IPs.
if i could do online or remote updates it could be more help full to me...
Thanks a lot....
Srinivas.
Thanks & Regards,
Srinivas.
HI Srinivas ,
You can setup a TFTP Server with all the requiered images needed at your site .
You can remotely login to each device and issue the copy tftp: flash: andprovide the image needed for your platform .
Cisco 2960 is a L2switch and we can expect only L3 behaviour . Ios upgrade will resolve your bugs in the exsisting images . Please reffer the release notes for the software release .
Angus
If you want to be able to look or make changes to the switch via http or https , i will download and load on the switch the .tar image that include the web server (http, https).
The .tar imag will include you.bin file and you will also have a web server loaded on the switch, you will have the option to enable it ip http server or disable it no ip http server, same thing for https ip https server and no ip https server.
Hope it helps.
And also another advantage for having the http server is that u can do the software update using that gui from the https(s) server, you don,t have to worry about the tftp server and you will also be able to manage the switch (depending on the model) usign Cisco Network Assistant.
Hope it helps.
