IOS upgrade problem
muca
Level 3
Level 3
Has anybody faced problems of link performance after upgrading flash,
dram memory and IOS? Does it make sense? Considering that I have the
minimum requirements to run the new IOS version?
5 Replies 5
thisisshanky
Level 11
Level 11
It depends. There could be some incompatibility or caveat with the IOS you upgraded to, that might be causing this. What IOS are you running and what hardware do you got. Can you paste a sh version ?
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
Thisisshanky, it is an enterprise version. I have compared with the old version using feature navigator and it seems to be compatible.
Cisco 2621
ADJ_Petropolis#sh version
IOS (tm) C2600 Software (C2600-IK9S-M), Version 12.2(11)T3, RELEASE SOFTWARE (f
c2)
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2002 by cisco Systems, Inc.
Compiled Sun 22-Dec-02 02:19 by ccai
Image text-base: 0x8000809C, data-base: 0x817E15D0
ROM: System Bootstrap, Version 12.2(6r), RELEASE SOFTWARE (fc1)
ADJ_Petropolis uptime is 12 minutes
System image file is "flash:c2600-ik9s-mz.122-11.T3.bin"
cisco 2621 (MPC860) processor (revision 0x00) with 60416K/5120K bytes of memory.
Processor board ID JAD062808D2 (2467102882)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Not enterprise, ip plus ipsec 3des
How can I check if there is some caveat with this particular version?
I don´t have access to bug tool kit.
TIA
Hi muca,
You can check out this link if the IOS version you are using has deferral notices associated with it.
http://www.cisco.com/kobayashi/sw-center/sw-ios-advisories.shtml
Cheers,
Chris
