IOS Upgrade through console in cisco 2500
william2u
I want to upgraded ios in cisco 2500 router . kindly advise me in this regard
thanks in advance
thanks
*2500 console do not support console rite ?
locp
Hi Williams,
Of course you can, here is a tip:
http://www.cisco.com/en/US/products/hw/routers/ps259/products_tech_note09186a008015bfac.shtml
I done it a few times, it will take some hours but can be done.
HTH,
Loc P
are u sure 2500 do support xmodem for Console !?!?
csco10837896
If you are in rommmon mode try following command:
connect router e0 to machine ethernet with cross cable.
following are list of command:
IP_ADDRESS=PC GATEWAY IS THIS IP
SUBNET_MASK=SAME AS YOUR PC
DEFAULT_GATEWAY=YOUR PC IP
TFTP_SERVER=YOUR PC IP
TFTP_FILE=WHICH IOS YOU WANT TO UPLOAD,IT MUST IN THE TFTP DIRECTORY.
tftpdnld.
I think this will help you.
Please rate this,
regards,
Yogesh
