IOS-XE - 3.7.0 - Unable to remove configuration
Pedro Morais
Hello all,
When doing some tests with an ASR1K running 3.7.0.S, I noticed that everytimes I reload the router, I got the following error when it loads the configuration:
mpls ldp discovery accept-targeted-hellos 15
% Invalid input detected at '^' marker.
However when I try to remove the configuration I'm not able to:
A1K-LAB03#conf t
A1K-LAB03(config)#no mpls ldp discovery accept-targeted-hellos 15
Does anyone have an idea on how to remove this configuration line?
Thanks.
Cheers,
Pedro
Giuseppe Larosa
Hello Pedro,
the only parameter that it doesn't like is the last one that is a timer
to remove the command I think you should do
WARNING:  if you are running LDP based EoMPLS it may be better to live with this minor issue, or the risk is that the box will not accept targeted LDP sessions if you remove the command
Hope to help
Giuseppe
