Showing results forĀ
Search instead forĀ
Did you mean:Ā
IOS XE Static NAT with route map
Hi there,
Are there any limitations regarding static NAT implemented with route map on ISR 4321 routers?
I have configured two static NATs but only one is translating. Other one is not translating, it keeps the original source address.
This seems to be very confusing, because along mentioned two static NATs with route map I have a lot of others that are translating just fine.
Than you and kind regards,
Miroslav
Hello
Can you explain a little further as to what you are trying to accomplish and maybe post the configuration also.
res
Paul
Kind Regards
Paul
Hi Paul,
The configuration is following:
ip nat inside source static 10.10.19.10 10.10.40.20 route-map NAT-A
ip nat inside source static 10.10.19.10 10.10.50.30 route-map NAT-B
route-map NAT-A permit 10
 match ip address A_to
ip access-list extended A_to
 permit ip any host 10.0.15.25
route-map NAT-B permit 10
 match ip address B_to
ip access-list extended B_to
 permit ip any host 10.220.100.30
When trying to access 10.0.15.25 translation is OK, source address is translating into 10.10.40.20. But when trying to access 10.220.100.30 translation is not occurring.
Swapping of translation addresses is tried but with no success. Source is always translated for route map A, but not for B.
Match commands under the route-map statement are swapped, but again only route map A is matched.
New route map is created to replace B route map but with the same result.
When debug is turned on message ipnat_update_static_refcnt - nat entry 0x7FD21A0698A0  mapping_id 59 updated - nat->refcount 1 nat->usecount 1 is printed for A route map but for B there is nothing.
One interesting thing happened also, when access list C was removed, that is used for static NAT below, NAT for route map B started translating.
ip nat inside source static 10.11.12.75 10.10.13.67 route-map NAT-C
ip nat inside source static 10.11.12.79 10.10.13.68 route-map NAT-C
ip nat inside source static 10.11.12.80 10.10.13.80 route-map NAT-C
ip nat inside source static 10.11.12.84 10.10.13.83 route-map NAT-C
ip nat inside source static 10.11.12.74 10.10.13.84 route-map NAT-C
ip nat inside source static 10.11.12.83 10.10.13.90 route-map NAT-C
ip nat inside source static 10.11.12.77 10.10.13.91 route-map NAT-C
ip nat inside source static 10.11.12.78 10.10.13.92 route-map NAT-C
ip nat inside source static 10.11.12.82 10.10.13.93 route-map NAT-C
ip nat inside source static 10.11.12.76 10.10.13.99 route-map NAT-C
route-map NAT-C permit 10
match ip address C_to
ip access-list extended C_to
deny ip any host 10.21.54.15
permit ip any any
I hope that is something clearer now.
Kind regards,
Miroslav
