IOS-XR /24 OSPF Loopback Advertisement
I am trying to advertise a loopback with a /24 subnet mask into OSPF however due to it's default behavior its still advertising it as a /32.
I have added "network point-to-point" under the interface but still see it showing as a /32 in the routing table.
What am I missing?
router ospf 1
router-id 1.1.1.1
auto-cost reference-bandwidth 19000
address-family ipv4 unicast
area 0
interface Loopback100
interface GigabitEthernet0/0/0/3
end
Cristian Matei
    IOS-XR does not support changing the OSPF network-type for Loopback interface, so your configuration is ignored; you can check by issuing command "show ospf interface Loopback100"; this was actually a tweak on IOS-XE.
   On IOS-XR, if you want to advertise the Loopback with its original mask, you ned to globally, under OSPF process, configure Loopbacks as stub networks via command "loopback stub-network enabled"; from the RFC perspective, this is a cleaner and more logical way of doing it.
Best,
Cristian.
Cristian Matei
Best,
Cristian.
@ThomasCampbell64
Try to advisertise with redistribute connected
   Redistribute connected, although resolves the challenge, should be avoided at all costs within MPLS environment for many reasons; even if this would be a pure IP environment, always use the solution which was designed to fix the problem, not a workaround like distribution which fixes the problem but brings other perks alongside.
Best,
Cristian.
