Cisco 1941 speed limitation
ciscoreg2
Hi, I have tested the cisco 1941 router the speed only reach around 180+- Mbps in Gigabit internet line. So this device the maximum design speed is this?
[ 5] 0.00-1.02 sec 22.4 MBytes 185 Mbits/sec
[ 5] 1.02-2.02 sec 21.9 MBytes 183 Mbits/sec
[ 5] 2.02-3.01 sec 21.8 MBytes 184 Mbits/sec
[ 5] 3.01-4.01 sec 21.5 MBytes 181 Mbits/sec
[ 5] 4.01-5.01 sec 21.8 MBytes 182 Mbits/sec
[ 5] 5.01-6.01 sec 21.6 MBytes 182 Mbits/sec
[ 5] 6.01-7.01 sec 22.0 MBytes 185 Mbits/sec
[ 5] 7.01-8.01 sec 21.8 MBytes 182 Mbits/sec
[ 5] 8.01-9.00 sec 21.8 MBytes 183 Mbits/sec
[ 5] 9.00-10.01 sec 21.9 MBytes 182 Mbits/sec
Blue_Bird
Hello ciscoreg2 ,
Please go through the following link..
https://community.cisco.com/t5/routing/can-a-cisco-1941-router-handle-a-100-mbps-internet-circuit/td-p/2892595
Best regards
******* If This Helps, Please Rate *******
balaji.bandi
what version of code running, do you have throughput license installed any ?
Also Limitation on that router throughput on that WAN interface. if you need to Gigabit full wire speed, you need move to higher models like ISR or ASR or cat 8K depends on the budget.
If this is home router- then buy a Firewall is good option here rather WAN Router.
BB
