IOS-XR - How to get ZTP to start iPXE
h.lehnigk
Hello Team,
I try to upgrade large number of NCS55 and would like to use ZTP helping me with iPXE. For that I use a Linux machine with dhcp an web server. The DHCP Server is able to differentiate between iPXE and ZTP and if I start iPXE by command it runs fine.
My user script looks like that, but I am not sure if the confirmation with yes would work:
#   Script use admin to start iPXE Boot                                     #
source /pkg/bin/ztp_helper.sh
export AAA_User=admin  && echo -ne "hw-module location all bootmedia network reload\n" | xrcmd "admin"
export AAA_User=admin  && echo -ne "yes\n" | xrcmd "admin"
The main problem from my point of view is that the machine will not execute the script and I have no idea where to find the error logs. I doesn't matter what I write into the script the ztp log looks alway like that:
2020-09-30 13:48:24,888 [INFO] {7857 : Engine} Begin executing user script in Global VRF NS...:
2020-09-30 13:48:24,935 [ERRO] {7857 : Engine} Failed executing script /disk0:/ztp/customer/config.candidate, with shell /bin/bash. Error ZError('Error executing command ip netns exec global-vrf /bin/bash -c /disk0:/ztp/customer/config.candidate: ',). Log saved at <_io.BufferedWriter name='/var/log/ztp_user_script.log'>
2020-09-30 13:48:24,935 [INFO] {7857 : Engine} Rolling back to previous state
2020-09-30 13:48:24,935 [DEBU] {7857 : Engine} Rolling back to the commit id 1000000116 using rollback configuration to-exclude 1000000116
2020-09-30 13:48:24,935 [DEBU] {7857 : Engine} Executing: source /pkg/bin/ztp_helper.sh && echo -ne  | xrcmd "rollback configuration to-exclude 1000000116"
(XR Network NS                 ) Wed Sep 30 13:48:25 UTC 2020: (pid  9705) (/pkg/bin/ztp_exec.sh)                  : Running user cmd: [rollback configuration to-exclude 1000000116]
Loading Rollback Changes.
Loaded Rollback Changes in 1 sec
Committing.2020-09-30 13:48:27,976 [INFO] {7857 : Engine} Waiting on config apply finish
2020-09-30 13:48:27,976 [DEBU] {7857 : Engine} Applying XR config revert file
2020-09-30 13:48:27,977 [DEBU] {7857 : Engine} Will apply the following: /disk0:/ztp/xr_config/xr_config_to_revert
(XR Network NS                 ) Wed Sep 30 13:48:28 UTC 2020: (pid  9821) (/pkg/bin/ztp_exec.sh)                  : Applying configuration (Reverting to xr config revert file.):
Maybe there is somebody how has done this and can help me.
Hubert
I have the same issue.
Did you find a way to solve it?
Thank you
BR
Hello Christian,
We run this solution with ZTP since two years now. I solved it with TAC. You need for ZTP a signed Golden Image. If you bake one by yourself it will run with PXE boot but not with ZTP.
Hubert
