IOS XR not support encapsulation dot1q second-dot1q any
hello, i have router A9K with XR OS (v6.6.3),
I try to create a subinterface with double encapsulation, but a
second-dot1q
  is not supported, and or range VLANs ?
RP/0/RSP0/CPU0:BNG-A9K(config)#int Te0/3/0/2.920
RP/0/RSP0/CPU0:BNG-A9K(config-subif)#encapsulation dot1q 100 second-dot1q ?
<1-4094> Configure second (inner 802.1Q) VLAN ID on the subinterface
RP/0/RSP0/CPU0:BNG-A9K(config-subif)#encapsulation dot1q 100 second-dot1q any
% Invalid input detected at '^' marker.
RP/0/RSP0/CPU0:BNG-A9K(config-subif)#encapsulation dot1q 100 second-dot1q 2-90 ^ % Invalid input detected at '^' marker.
Hello, i found the solution , i must use ambiguous.
A9K# encapsulation ambiguous dot1q 1 second-dot1q any
7 Replies 7
balaji.bandi
Not sure you configuring right way : ( i do not believe that any support as per the version or range)
example :
RP/0/RSP0/CPU0:BNG-A9K(config-subif)#encapsulation dot1q 100 second-dot1q 20
or look at the config document :
https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-3/interface/configuration/guide/b-interfaces-hardware-component-cg-asr9000-63x/b-interfaces-hardware-component-cg-asr9000-63x_chapter_010100.html
BB
yes is supporting second vlan,
but i need second vlan is range of vlans
not one,
in documentation of cisco is must supported,
but on router i can’t find the commend
 It seems it is complaining about the first vlan 100. Does it exist?
i try two times,
one without VLAN exist, second with VLAN exit.
same results
does it take the 'any' keyword ?
is solved by use
