IOS XR route-policy
jvoorend
Under Cisco IOS I have the following:
route-map RPA-SET-MED permit 10
match ip address prefix-list RPA-HTC-DMZ-NETWORKS
set metric 50
set community 4771:120
route-map RPA-SET-MED permit 20
set metric 300
Under IOS XR for an equivalent route-policy as per above what is the equivalent command for "set metric" as set metric is not available under XR ?
Giuseppe Larosa
Hello @jvoorend ,
according to the following document in IOS XR you can use
set med <value>
https://www.cisco.com/c/en/us/td/docs/iosxr/cisco8000/routing/70x/b-routing-cg-cisco8000-70x/implementi-routing-policy.html?dtid=osscdc000283
the link is for IOS XR 7.0, but it is likely not a new command.
Hope to help
Giuseppe
Hello
Ive never used software this however I interpret your IOS route-map as the following in IOS-XR RPL : Here
ipv4 prefix-list RPA-HTC_DMZ-NETWORKS
permit x.x.x.y/24
route-policy RPA-SET-MED
if destination in RPA-HTC_DMZ-NETWORKS then
set med 50
endif
if not destination in RPA-HTC_DMZ-NETWORKS then
set med 300
endif
end-policy
Kind Regards
Paul
jvoorend
Many thanks for the replies. Confirms my thinking with regard to config setup.
Cheers
