%IOSXE-3-PLATFORM: R0/0: cmand: Clocking device Parity Error occured
psymonds7769
Has anyone seen this log message in a Cisco ASR 920 before?
Hi Flavio, hi psymonds7769,
The document referred to Flavio is a nice general introduction to parity errors but it is specific to ASR9000 IOS-XR devices while here, the router is an ASR920 running IOS XE.
I've checked internally - on RSP2, there is a clocking chip providing clocking signal to some of the hardware components. IOS XE periodically verifies if the processor of this clocking chip responds correctly to a status poll. If it does not, IOS XE produces the "Clocking device Parity Error occured" message. I would even say that the
parity error
is a little misleading here but that is just my personal opinion.
Usually, this is a transient error that is resolved by a reload, and is unlikely to reoccur. However, if it reappears even after a reload, it is best to open a TAC case for this, as it might be necessary to RMA the device.
So, if you can afford a reload in a maintenance window, consider giving it a try, and let's take it from there.
Best regards,
Peter
5 Replies 5
parity error
Best regards,
Peter
From your description,
parity error
does seem a bit of a misnomer.
marce1000
             - FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCvp32921
 M.
Hi ; ),
Indeed, there were a few software defects related to the same symptom - but the one you have mentioned is related to a stateful switchover (SSO). This is not applicable to ASR920 since these do not have redundant RSPs, and so they cannot perform a SSO which is the trigger for the defect above.
Best regards,
Peter
