Catalyst 8000v and subinterfaces
Clifford McGlamry
On an 8000v router, is it possibly to configure subinterfaces?  If it's possible, how do you connect the additonal VLANs to the VM?
Peter Paluch
Hi Clifford,
There does not seem to be any issue with configuring the subinterfaces on the C8000v image alone. What is the hypervisor you're running this VM in?
Best regards,
Peter
