IP Access-Group on switchport - Cisco C1111 ISR Router
S Leigh
Hi all.
I am attempting to add an access group to a switch port which is located in a C1111 ISR router but the command is no longer there when using version c1100-universalk9.17.06.03a.SPA.bin
My-Router(config-if)#ip a?
admission  arp  auth-proxy
But when using c1100-universalk9_ias.16.09.06.SPA.bin the command is available
R01(config)#int GigabitEthernet0/1/1
R01(config-if)#ip a?
access-group  admission  auth-proxy
Does anyone know of a way round this so an ACL can be attached to an interface?
interface GigabitEthernet0/1/1
ip access-group ACL-Default in
10 Replies 10
M02@rt37
Hello @S Leigh
do you have this command under interface GigabitEthernet0/1/1?
service-policy ?
If yes, one workaround is to use the "service-policy" command to apply a policy-map that includes your access-list to the interface. Here's an example configuration:
ip access-list standard MY-ACL
permit 10.10.10.0 0.0.0.255
class-map MY-CLASS
match access-group name MY-ACL
policy-map MY-POLICY
class MY-CLASS
police 1000000
service-policy input MY-POLICY
In the above configuration, we create a standard IP access-list called "MY-ACL" that permits traffic from the 10.10.10.0/24 subnet. We then create a class-map that matches the "MY-ACL" access-list, and a policy-map that applies a policer to that class.
Finally, we apply the "MY-POLICY" policy-map to the interface using the "service-policy" command. This will cause traffic matching the access-list to be policed on the interface.
Best regards
what you meaning !!! using service-policy instead of ACL ??
that so wired
Hello @MHM Cisco World
yes it's wired, wired also that the command is no longer available there when using version c1100-universalk9.17.06.03a.SPA.bin....
it's a "tricky wired" solution which help me at the past lol No way to downgrade or upgrade my C1111 ISR Router.
Best regards
ok, let if the interface is L3 then at least ip add must appear, are the interface accpet the IP add command ??
@MHM Cisco World
ok you mean, do a "no switchport" command on that interface ?
Best regards
I think so,
he enter ip then a? one of command must appear is address,
but it dont appear, I think he use L2 interface and hence ip access-group is missing
let wait his reply to confirm
Hi All.
Just to remove any confusion here.
On one of my Ciso C1111 router that has a built in switchport module of 8 ports i was able to add an access list to one of the switch ports.
Ususal way -> int gxx/xx/xx -> ip access-group  ACL-Default in
I have done this on multiple switchports running version IOS - XE 16.09.06
I upgrade to 17.06.03a and the command to put in "ip access-group" is no longer there.
When reloading the router with the new ios and the saved config i get an error when looking at the console when it hits the ip access-group  ACL-Default in.
let start with show license
let check the IPbase status
S Leigh
 an update it turns out that the ability to add access-lists directly to the inbuilt switch ports, (Its a active layer 3 device) is no longer their in the later releases of software, confirmed by TAC
Maybe one day the function will return
Could you not add the access-group to the VLAN interface, if configured?
