Hi Folks,
I need a little help. I have 2 sites that are connected by a metro ethernet using a 3560 & 3750. We experience a congestion, I tried to run ipaccounting on the interface vlan that links the site.
I was able to apply it on the 3750G but when I do show ip accouting it doesn't give me anything. After googling it appears that ipaccounting if not supported on the switch.
Is the anyther way for me to look at the top tem talkers?
Thank you in advanced I appreciate it.
JP
