IP Accouting
antonyjaison
Even after enabling ip accounting on interfaces , i am not seeing any output when i put sh ip accounting command. Any idea about it??
Jaison
sonasoma
what type of traffic is passing that interface, if you are using VPN tunnel and all means , it will not show anything. Likewise you can try ip cache flow .
S.soma
You can use some flow control to check that..
chuckbrantley
Are you using any kind of MLS? MLS will not provide the IP accounting process with any input to provide the user with an output....
Chuck
