01-04-2012 02:28 PM - edited 03-04-2019 02:49 PM
Dears
I would like your assistance regarding below plz
when I configure "access-list permit ip any any"
Actually this will permit all IP packets
However what about L2 protocols/packets as MPLS, VPLS, ... etc
Will it match ? According to lab I made, It didnt match but packets were permitted
So this means, If I configured this access-list under any interface
It will only filter IP packets & all other protocols rather than IP (as MPLS, VPLS or even IPX) will not be filtered & will be permitted normally
Am I correct ?
Many Thanks
Sherif Ismail
01-04-2012 03:28 PM
MPLS adjancencies will use TCP port 646 for LDP so an IP ACL will affect it.
01-04-2012 09:50 PM
certainly ipx is unaffected. There are separate acls for ipx.
01-04-2012 10:13 PM
Thanks Edison/Jeff
@ Edison
what about mpls traffic that passes after LDP adjancies are up
So this means my statment is right , correct ?
So this means, If I configured this access-list under any interface It will only filter IP packets & all other protocols rather than IP (as MPLS, VPLS or even IPX) will not be filtered & will be permitted normally
Many Thanks
Sherif Ismail
01-05-2012 06:38 AM
MPLS transport itself won't be affected.
01-05-2012 10:12 PM
Thanks Edison
