Ip address dhcp issue
akintokun
I have 2x 1941 routers that i connect both WAN interfaces to a Netgear DSL router or I connect all three connections to ports on the same vlan on my 2960 switch. I configure the WAN interfaces on the router to receive IP address via DHCP.
None of routers receive an IP address or sometimes only one of them. Even if I release and renew the lease nothing happens. However if I connect a laptop to the port the laptop receives an IP address without a issue. The same issue happens with different Cisco routers too.
When I run a DHCP debug on the router i receive the following message repeatedly.
*:19:27.055: DHCP: SDiscover: sending 293 byte length DHCP packet
*:19:27.055: DHCP: SDiscover 293 bytes
*:19:27.055: B'cast on FastEthernet0 interface from 0.0.0.0
*:19:27.071: DHCP: Received a BOOTREP pkt
*:19:27.071: DHCP: rcv nak 192.168.100.1 is not our server 0.0.0.0
*:19:27.071: DHCP: rcv nak in Selecting state: punt
cadet alain
I don't understand this part?
Could you do a simple drawing of the topology.
Post configs from 1941s and the dhcp scopes from the Netgear.
Regards.
Alain.
