Serial bandwidth upgrade
marcusbrutus
I guess this is more of a service provider question.  If i wish to upgrade from a T1 to a T2 frame relay connection, apart from changing the bandwidth on the serial interface on the router, are there other changes required as well?
Thanks.
Joseph W. Doherty
Disclaimer
The    Author of this posting offers the information contained within this    posting without consideration and with the reader's understanding that    there's no implied or expressed suitability or fitness for any  purpose.   Information provided is for informational purposes only and  should not   be construed as rendering professional advice of any kind.  Usage of  this  posting's information is solely at reader's own risk.
Liability Disclaimer
In    no event shall Author be liable for any damages whatsoever  (including,   without limitation, damages for loss of use, data or  profit) arising  out  of the use or inability to use the posting's  information even if  Author  has been advised of the possibility of such  damage.
Posting
A provider is offering you a "T2" frame-relay connection?
Reason I ask, normally you might have multipe T1s bound with MLPPP or move to a T3 although perhaps with "fractional" bandwidth.
