Ip address dhcp
Mero Cisco
I have taken an internet account with an isp. The account is a dhcp account and I have to give username and password from webpage while connecting it through computer. Is it possible to connect the same link with cisco 1841 router. I got the ip address when I issue ip address dhcp on interface. How to pass username and password through this.
Mero
Richard Burts
Mero
You can pass the username by using the command ip address dhcp hostname. I am not sure of how to include the password. See this link for details
http://www.cisco.com/c/en/us/td/docs/ios-xml/ios/ipaddr/command/ipaddr-cr-book/ipaddr-c1.html#wp3343120296
Rick
Rick
5 Replies 5
Richard Burts
Mero
Rick
Rick
feltinsilije
Have you try with this command ???
username xxxxxx privilege 15 password xxxxxx
Dear Feltinsilije,
This is for router login command.
Mero
susanng90
I have  a 831 router use PPPoE. Please note that is a PPPoE seting.
interface Ethernet0
ip address (LAN IP ADD)
ip nat inside----> must in my case
interface Ethernet1
no ip address
ip nat outside
duplex auto
pppoe enable
pppoe-client dial-pool-number 1
no cdp enable
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap pap callin callout
ppp chap hostname xxxxxxxxxxxxxxxxxxxxxxxx (may need, please ask your ISP)
ppp chap password 7 xxxxxxxxxxxxxxxxxxxx (may need, please ask your ISP)
ppp pap sent-username abc@singtel.com password 123456 ----> must in my case
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip nat inside source list nat_address interface Ethernet1 overload--->Must in my case
To see if u get IP debug ppp negotiation and debug ppp authentication .
Dear Sir,
This is not a PPPoe Account
Mero
