Showing results forĀ
Search instead forĀ
Did you mean:Ā
ip as-path access-list Question
pfrancois
I'm writing the following command "Ip as-path access-list 1 permit ^$", but when i do a sh run im only seeing  "Ip as-path access-list 1 permit ^" i cant understand why the "$" is not saving in the running config, any ideas?
Martin L
I think that is special character that may need special key to be entered before "$"  I had link with IOS explanation ... see this
To use these special characters as single-character patterns, remove the special meaning by preceding each character with a backslash (\). The following examples are single-character patterns matching a dollar sign, an underscore, and a plus sign, respectively.
source: https://www.cisco.com/c/en/us/td/docs/ios-xml/ios/fundamentals/configuration/xe-16-6/fundamentals-xe-16-6-book/cf-cli-search.html
also see https://community.cisco.com/t5/routing/can-t-set-special-character-in-enable-secret-password-string/td-p/3214879
 https://community.cisco.com/t5/xr-os-and-platforms/ios-xr-vrf-configuration-quot-quot-character/td-p/3083935
Regards, ML
**Please Rate All Helpful Responses **
I run lab and I see ^$ in show run
so I think it bug in your IOS
Hello
can you confirm what software train you are using ?
Kind Regards
Paul
