IP Cameras and 2951 Router Issue
tensi0n519
Hello all,
I am having the following issue with my home lab:
Equipment: Cisco Catalyst Switch 2960-S POE 750W, Cisco 2951 Router running IOS 15.1
I am having an issue with a few IP (POE) cameras causing my switch CPU to run high which causes connectivity issues and my IP cameras to drop frames. I have the camera set up on their own VLAN. It appears that no matter what IP camera I plug into the switch, it starts sending several packets to the router which bogs things down. Prior to using the 2951 router, I was using a pfsense box with the 2960 switch. I had the same vlan setup and the cameras were all working without issues and I was getting no high cpu usage on the switch. I can't see to figure out what the problem is.
The cameras are on vlan 70 and plugged into switchports 1/0/1,3,5, etc. The router is plugged into the switchport 1/0/42. I have a number of devices reserved by client-id or hardware-address, including the cameras. Here are the switch and router configs. Some items like my IP and password stuff I removed from the configs. Hopefully this all makes sense. Thank you all for the help!
Router config:
MainRouter#sh run
Building configuration...
Current configuration : 11735 bytes
! No configuration change since last restart
version 15.1
hostname MainRouter
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/2
enable secret
no aaa new-model
clock timezone PST -8 0
clock summer-time PDT recurring
no ipv6 cef
ip source-route
ip cef
ip dhcp excluded-address 10.10.1.1 10.10.1.100
ip dhcp excluded-address 10.10.10.1 10.10.10.100
ip dhcp excluded-address 10.10.10.200 10.10.10.254
ip dhcp excluded-address 10.10.20.1 10.10.20.100
ip dhcp excluded-address 10.10.20.200 10.10.20.254
ip dhcp excluded-address 10.10.30.1 10.10.30.100
ip dhcp excluded-address 10.10.30.200 10.10.30.254
ip dhcp excluded-address 10.10.40.1 10.10.40.100
ip dhcp excluded-address 10.10.40.200 10.10.40.254
ip dhcp excluded-address 10.10.50.1 10.10.50.100
ip dhcp excluded-address 10.10.50.200 10.10.50.254
ip dhcp excluded-address 10.10.60.1 10.10.60.100
ip dhcp excluded-address 10.10.60.200 10.10.60.254
ip dhcp excluded-address 10.10.70.1 10.10.70.100
ip dhcp excluded-address 10.10.70.200 10.10.70.254
ip dhcp pool MainLAN
import all
network 10.10.1.0 255.255.255.0
default-router 10.10.1.1
dns-server 209.18.47.61 209.18.47.62
domain-name MainLAN
ip dhcp pool Management
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
domain-name Management
ip dhcp pool Servers
network 10.10.20.0 255.255.255.0
default-router 10.10.20.1
domain-name Servers
ip dhcp pool SecureData
network 10.10.30.0 255.255.255.0
default-router 10.10.30.1
domain-name SecureData
ip dhcp pool GuestData
network 10.10.40.0 255.255.255.0
default-router 10.10.40.1
domain-name GuestData
ip dhcp pool GuestWifi
network 10.10.60.0 255.255.255.0
default-router 10.10.60.1
domain-name GuestWiFi
ip dhcp pool CCTV
network 10.10.70.0 255.255.255.0
default-router 10.10.70.1
domain-name CCTV
ip dhcp pool MainSwitch
host 10.10.10.2 255.255.255.0
client-identifier 0164.d814.071a.80
ip dhcp pool ServerSwitch
host 10.10.10.3 255.255.255.0
client-identifier 0134.bdc8.098d.80
ip dhcp pool FamilyRoomSwitch
host 10.10.10.4 255.255.255.0
hardware-address 6cb0.ce00.a246
ip dhcp pool MasterBedSwitch
host 10.10.10.5 255.255.255.0
client-identifier 0178.d294.aace.d1
ip dhcp pool GarageSwitch
host 10.10.10.6 255.255.255.0
client-identifier 01a0.0460.2129.36
ip dhcp pool ShedSwitch
host 10.10.10.7 255.255.255.0
hardware-address 841b.5e69.551d
ip dhcp pool HallwayAP
host 10.10.10.10 255.255.255.0
client-identifier 0180.2aa8.8688.49
ip dhcp pool GarageAP
host 10.10.10.11 255.255.255.0
client-identifier 01fc.ecda.f353.31
ip dhcp pool BackyardAP
host 10.10.10.12 255.255.255.0
client-identifier 0180.2aa8.8688.e5
ip dhcp pool NVR
host 10.10.70.2 255.255.255.0
client-identifier 0128.57be.94af.2f
ip dhcp pool FrontGateCamera
host 10.10.70.3 255.255.255.0
client-identifier 0100.18ae.6374.e4
ip dhcp pool CourtyardCamera
host 10.10.70.4 255.255.255.0
client-identifier 0100.18ae.6374.f2
ip dhcp pool DrivewayCamera
host 10.10.70.5 255.255.255.0
client-identifier 0100.18ae.6374.d0
ip dhcp pool PatioCamera
host 10.10.70.6 255.255.255.0
client-identifier 0100.18ae.529b.7a
ip dhcp pool WestSideCamera
host 10.10.70.7 255.255.255.0
client-identifier 0100.18ae.6375.13
ip dhcp pool BackyardCamera
host 10.10.70.8 255.255.255.0
client-identifier 0100.18ae.6374.f7
ip dhcp pool EastSideCamera
host 10.10.70.9 255.255.255.0
client-identifier 0100.18ae.6375.02
ip dhcp pool SouthPTZCamera
host 10.10.70.10 255.255.255.0
client-identifier 01f0.0000.2081.f4
ip dhcp pool ChickenCamera
host 10.10.70.11 255.255.255.0
hardware-address e061.b251.3f9e
ip dhcp pool GarageCamera
host 10.10.70.12 255.255.255.0
client-identifier 0100.13e2.fa63.0f
ip dhcp pool ShedCamera
host 10.10.70.13 255.255.255.0
client-identifier 0100.18ae.6374.da
ip dhcp pool WeatherCamera
host 10.10.70.14 255.255.255.0
client-identifier 013c.8cf8.a104.ba
voice-card 0
license udi pid CISCO2951/K9 sn FTX1819AJKF
hw-module pvdm 0/0
hw-module pvdm 0/1
hw-module sm 2
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address dhcp
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip address 10.10.1.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface GigabitEthernet0/1.10
description Management VLAN
encapsulation dot1Q 10
ip address 10.10.10.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.20
description Servers VLAN
encapsulation dot1Q 20
ip address 10.10.20.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.30
description SecureData VLAN
encapsulation dot1Q 30
ip address 10.10.30.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.40
description GuestData VLAN
encapsulation dot1Q 40
ip address 10.10.40.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.60
description GuestWifi VLAN
encapsulation dot1Q 60
ip address 10.10.60.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.70
description CCTV VLAN
encapsulation dot1Q 70
ip address 10.10.70.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source list 20 interface GigabitEthernet0/0 overload
ip nat inside source list 30 interface GigabitEthernet0/0 overload
ip nat inside source list 40 interface GigabitEthernet0/0 overload
ip nat inside source list 60 interface GigabitEthernet0/0 overload
ip nat inside source list 70 interface GigabitEthernet0/0 overload
ip route 0.0.0.0 0.0.0.0 ***IP ADDRESS REMOVED** 254
access-list 1 permit 10.10.1.0 0.0.0.255
access-list 20 permit 10.10.20.0 0.0.0.255
access-list 30 permit 10.10.30.0 0.0.0.255
access-list 40 permit 10.10.40.0 0.0.0.255
access-list 60 permit 10.10.60.0 0.0.0.255
access-list 70 permit 10.10.70.0 0.0.0.255
nls resp-timeout 1
cpd cr-id 1
control-plane
mgcp profile default
gatekeeper
shutdown
line con 0
exec-timeout 0 0
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 4
password
login
transport input all
scheduler allocate 20000 1000
ntp master 1
end
MainRouter#
Switch Config:
MainSwitch#sh run
Current configuration : 8655 bytes
! Last configuration change at 07:27:21 PST Sat Jan 4 2020 by ryan
! NVRAM config last updated at 07:28:24 PST Sat Jan 4 2020 by ryan
version 15.0
no service pad
service password-encryption
hostname MainSwitch
boot-start-marker
boot-end-marker
enable password
username
no aaa new-model
switch 1 provision ws-c2960s-48fps-l
no ip domain-lookup
ip domain-name mainswitch.skynet
vtp mode transparent
spanning-tree mode rapid-pvst
spanning-tree loopguard default
spanning-tree portfast bpduguard default
vlan internal allocation policy ascending
vlan 10
name Management
vlan 20
name Servers
vlan 30
name SecureData
vlan 40
name GuestData
vlan 50
name SecureWiFi
vlan 60
name GuestWifi
vlan 70
name CCTV
vlan 71
vlan 150
name VOICE
vlan 900
name TestVLAN
ip ssh version 2
lldp run
interface Port-channel1
switchport trunk native vlan 10
switchport trunk allowed vlan 10,20,30,50,60,150
switchport mode trunk
interface FastEthernet0
no ip address
interface GigabitEthernet1/0/1
switchport access vlan 70
switchport mode access
spanning-tree bpduguard enable
interface GigabitEthernet1/0/2
description HallwayAP
interface GigabitEthernet1/0/3
interface GigabitEthernet1/0/4
switchport access vlan 30
interface GigabitEthernet1/0/5
interface GigabitEthernet1/0/6
switchport voice vlan 150
interface GigabitEthernet1/0/7
interface GigabitEthernet1/0/8
interface GigabitEthernet1/0/9
interface GigabitEthernet1/0/10
interface GigabitEthernet1/0/11
interface GigabitEthernet1/0/12
interface GigabitEthernet1/0/13
interface GigabitEthernet1/0/14
interface GigabitEthernet1/0/15
interface GigabitEthernet1/0/16
description Family Room Switch
switchport trunk allowed vlan 10,30,40
interface GigabitEthernet1/0/17
interface GigabitEthernet1/0/18
switchport access vlan 40
interface GigabitEthernet1/0/19
interface GigabitEthernet1/0/20
description Master Bedroom Switch
interface GigabitEthernet1/0/21
interface GigabitEthernet1/0/22
interface GigabitEthernet1/0/23
interface GigabitEthernet1/0/24
interface GigabitEthernet1/0/25
interface GigabitEthernet1/0/26
interface GigabitEthernet1/0/27
interface GigabitEthernet1/0/28
interface GigabitEthernet1/0/29
interface GigabitEthernet1/0/30
interface GigabitEthernet1/0/31
interface GigabitEthernet1/0/32
interface GigabitEthernet1/0/33
switchport trunk allowed vlan 1-99,150
interface GigabitEthernet1/0/34
interface GigabitEthernet1/0/35
interface GigabitEthernet1/0/36
switchport access vlan 900
interface GigabitEthernet1/0/37
switchport access vlan 71
interface GigabitEthernet1/0/38
power inline never
interface GigabitEthernet1/0/39
interface GigabitEthernet1/0/40
power inline never
interface GigabitEthernet1/0/41
interface GigabitEthernet1/0/42
description MainRouter
switchport trunk allowed vlan 10,20,30,40,50,60,70
power inline never
interface GigabitEthernet1/0/43
interface GigabitEthernet1/0/44
description BackupRouter
switchport trunk allowed vlan 10,20,30,40,50,60,70,900
interface GigabitEthernet1/0/45
channel-protocol lacp
channel-group 1 mode active
interface GigabitEthernet1/0/46
interface GigabitEthernet1/0/47
interface GigabitEthernet1/0/48
interface GigabitEthernet1/0/49
shutdown
interface GigabitEthernet1/0/50
shutdown
interface GigabitEthernet1/0/51
shutdown
interface GigabitEthernet1/0/52
shutdown
interface Vlan1
no ip address
interface Vlan10
ip address 10.10.10.2 255.255.255.0
ip default-gateway 10.10.10.1
ip http server
vstack
line con 0
exec-timeout 0 0
logging synchronous
line vty 0 4
exec-timeout 0 0
password
login local
transport input ssh
line vty 5 15
exec-timeout 0 0
password 7
login local
transport input ssh
ntp server 10.10.1.1
end
MainSwitch#
Sooo.....
I decided to look at my flash: and found that there was a newer IOS, c2951-universalk9-mz.SPA.154-3.M3.bin.
I decided to reboot the router with the newer IOS and now the problem is gone!
So going from c2951-universalk9-mz.SPA.151-4.M1.bin to c2951-universalk9-mz.SPA.154-3.M3.bin seems to have fixed my issue. If only I could get those lost hours back.....
Thank you to all who responded to help me! Very much appreciated.
22 Replies 22
what brand/type/model are the IP cameras ?
I'm not exactly sure. A family member of mine installs commercial security cameras and these are the ones I am using.
https://www.unixcctv.com/product/ip-power-mc532v-5mp-network-ip66-outdoor-ir-eyeball-camera-h-265-3-3-12mm-motorized-vf-lens-up-to-100ft-dc-12v-poe/
I'm afraid I don't have any further info on them. I've had them up and running for about 3 years now. Of course they weren't hooked up to Cisco gear until recently.
Thank you.
CPU of the switch checks out fine.
Router CPU looks good too.
What exactly is the problem?
Could be a multi-cast storm?
The more I've been researching this problem, the more I've been thinking the same thing as you. How would I go about fixing that?
Fixing what? I don't know what the problem is. Tell us what is going wrong (minus the "high CPU" bit).
gaston.benitez
hi.
Can you try to configure portfast on all cammera ports?
also. please. can you share the following output from the switch and the router ?
//from the switch
show spanning-tree detail | inc ieee|occurr|from|is exec (take this comand 2 or 3 times every 3 minutes)
show process cpu | e 0.00
//from the router
BR
Thank you very much for your response. Here is the information you requested.
"Can you try to configure portfast on all cammera ports?"
I initially had all of the camera ports with portfast configured, exactly like switchport 1. The results are the same and the switch and router have even higher cpu. I have a couple different brand cameras and all have the same results of different ports.
"also. please. can you share the following output from the switch and the router ?"
SWITCH:
MainSwitch#show spanning-tree detail | inc ieee|occurr|from|is exec
VLAN0010 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 11 last change occurred 00:04:31 ago
from GigabitEthernet1/0/42
VLAN0020 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 8 last change occurred 00:04:32 ago
VLAN0030 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 26 last change occurred 00:04:54 ago
VLAN0040 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 4 last change occurred 00:04:32 ago
VLAN0050 is executing the rstp compatible Spanning Tree protocol
VLAN0060 is executing the rstp compatible Spanning Tree protocol
VLAN0070 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 2 last change occurred 00:04:32 ago
VLAN0071 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 4 last change occurred 05:23:55 ago
from GigabitEthernet1/0/43
VLAN0150 is executing the rstp compatible Spanning Tree protocol
Number of topology changes 7 last change occurred 05:18:43 ago
from GigabitEthernet1/0/14
Number of topology changes 11 last change occurred 00:05:37 ago
Number of topology changes 8 last change occurred 00:05:37 ago
Number of topology changes 26 last change occurred 00:05:59 ago
Number of topology changes 4 last change occurred 00:05:37 ago
Number of topology changes 2 last change occurred 00:05:37 ago
Number of topology changes 4 last change occurred 05:25:00 ago
Number of topology changes 7 last change occurred 05:19:37 ago
Number of topology changes 11 last change occurred 00:07:52 ago
Number of topology changes 8 last change occurred 00:07:52 ago
Number of topology changes 26 last change occurred 00:08:14 ago
Number of topology changes 4 last change occurred 00:07:53 ago
Number of topology changes 8 last change occurred 00:07:53 ago
Number of topology changes 2 last change occurred 00:07:53 ago
Number of topology changes 4 last change occurred 05:27:16 ago
Number of topology changes 7 last change occurred 05:21:57 ago
MainSwitch#show process cpu | e 0.00
CPU utilization for five seconds: 55%/14%; one minute: 43%; five minutes: 41%
PID Runtime(ms) Invoked uSecs 5Sec 1Min 5Min TTY Process
4 567266 32328 17547 8.20% 1.26% 0.95% 0 Check heaps
10 110668 957 115640 2.10% 0.26% 0.18% 0 Licensing Auto U
86 28843 2541360 11 0.19% 0.08% 0.06% 0 RedEarth Rx Mana
104 34331 1429174 24 0.09% 0.12% 0.10% 0 HLFM address lea
122 29106 524312 55 0.09% 0.07% 0.08% 0 hpm main process
126 213345 57418 3715 0.39% 0.41% 0.39% 0 hpm counter proc
157 15347231 1431417 10721 23.51% 24.04% 24.32% 0 Hulc LED Process
168 124026 11466 10816 0.19% 0.20% 0.19% 0 HQM Stack Proces
185 273432 229055 1193 0.39% 0.32% 0.38% 0 Auth Manager
214 114551 407635 281 0.19% 0.11% 0.12% 0 Spanning Tree
285 14815 126437 117 0.19% 0.06% 0.03% 0 Marvell wk-a Pow
CPU utilization for five seconds: 46%/13%; one minute: 44%; five minutes: 41%
126 213397 57428 3715 0.49% 0.41% 0.39% 0 hpm counter proc
157 15350277 1431669 10721 26.28% 24.19% 24.34% 0 Hulc LED Process
168 124052 11468 10817 0.19% 0.20% 0.20% 0 HQM Stack Proces
169 34803 22916 1518 0.09% 0.06% 0.06% 0 HRPC qos request
185 273464 229095 1193 0.29% 0.31% 0.37% 0 Auth Manager
214 114574 407673 281 0.19% 0.13% 0.13% 0 Spanning Tree
285 14821 126459 117 0.09% 0.06% 0.03% 0 Marvell wk-a Pow
338 3827 622 6152 0.29% 0.49% 0.38% 5 SSH Process
CPU utilization for five seconds: 49%/13%; one minute: 42%; five minutes: 41%
4 574579 32737 17551 3.60% 1.40% 1.01% 0 Check heaps
55 23290 982 23716 0.59% 0.06% 0.01% 0 Per-minute Jobs
85 22188 537195 41 0.09% 0.03% 0.01% 0 RedEarth Tx Mana
86 29468 2570169 11 0.19% 0.11% 0.07% 0 RedEarth Rx Mana
104 35371 1445741 24 0.29% 0.12% 0.11% 0 HLFM address lea
106 17459 1446823 12 0.29% 0.08% 0.05% 0 HLFM address ret
122 29831 531283 56 0.09% 0.12% 0.09% 0 hpm main process
126 216304 58085 3723 0.50% 0.31% 0.37% 0 hpm counter proc
157 15534913 1448009 10728 24.11% 24.35% 24.34% 0 Hulc LED Process
168 125564 11599 10825 0.19% 0.19% 0.19% 0 HQM Stack Proces
169 35293 23178 1522 0.09% 0.07% 0.06% 0 HRPC qos request
185 276356 231798 1192 0.49% 0.36% 0.37% 0 Auth Manager
200 17309 1446125 11 0.09% 0.06% 0.02% 0 IP ARP Retry Age
214 115195 411146 280 0.19% 0.07% 0.07% 0 Spanning Tree
ROUTER:
MainRouter#show process cpu | e 0.00
CPU utilization for five seconds: 12%/5%; one minute: 6%; five minutes: 7%
31 480484 9790633 49 5.67% 2.71% 3.18% 0 ARP Input
68 140 18134 7 0.15% 0.14% 0.15% 0 Per-Second Jobs
86 248 72494 3 0.15% 0.19% 0.18% 0 Netclock Backgro
107 1988 36240 54 0.07% 0.04% 0.05% 0 BPSM stat Proces
111 12 2294562 0 0.07% 0.11% 0.10% 0 Ethernet Msec Ti
148 84 159 528 0.39% 0.12% 0.03% 644 Virtual Exec
CPU utilization for five seconds: 11%/5%; one minute: 7%; five minutes: 7%
31 480932 9800288 49 5.75% 3.16% 3.26% 0 ARP Input
68 140 18142 7 0.15% 0.13% 0.15% 0 Per-Second Jobs
86 248 72526 3 0.15% 0.19% 0.18% 0 Netclock Backgro
107 1992 36256 54 0.07% 0.04% 0.05% 0 BPSM stat Proces
111 12 2295555 0 0.07% 0.11% 0.10% 0 Ethernet Msec Ti
CPU utilization for five seconds: 12%/5%; one minute: 7%; five minutes: 7%
31 481160 9807673 49 5.75% 3.37% 3.30% 0 ARP Input
68 140 18148 7 0.15% 0.13% 0.15% 0 Per-Second Jobs
86 248 72550 3 0.15% 0.18% 0.17% 0 Netclock Backgro
107 1992 36268 54 0.07% 0.04% 0.05% 0 BPSM stat Proces
111 12 2296313 0 0.15% 0.11% 0.10% 0 Ethernet Msec Ti
148 104 169 615 0.15% 0.12% 0.03% 644 Virtual Exec
CPU utilization for five seconds: 10%/4%; one minute: 8%; five minutes: 7%
31 481356 9812540 49 5.67% 3.56% 3.34% 0 ARP Input
68 140 18152 7 0.07% 0.13% 0.15% 0 Per-Second Jobs
86 248 72566 3 0.23% 0.19% 0.18% 0 Netclock Backgro
111 12 2296829 0 0.07% 0.11% 0.10% 0 Ethernet Msec Ti
148 112 174 643 0.23% 0.13% 0.04% 644 Virtual Exec
CPU utilization for five seconds: 11%/4%; one minute: 8%; five minutes: 7%
6 11512 2820 4082 0.39% 0.08% 0.06% 0 Check heaps
31 494912 10131602 48 5.83% 4.27% 3.61% 0 ARP Input
68 144 18568 7 0.15% 0.13% 0.15% 0 Per-Second Jobs
86 256 74225 3 0.23% 0.19% 0.18% 0 Netclock Backgro
107 2088 37105 56 0.07% 0.04% 0.05% 0 BPSM stat Proces
111 12 2349204 0 0.15% 0.12% 0.10% 0 Ethernet Msec Ti
141 7208 85409 84 0.07% 0.02% 0.02% 0 IP Input
Hello
On ALL access ports enable stp portfast to negate stp transitions of the cameras and end hosts.
interface GigabitEthernet1/0/x
exit
Also can you confirm what is connected to the port-channel 1
Lastly you could clean up your nat configuration and change the default route on the rtr.
no ip source-route
no ip route 0.0.0.0 0.0.0.0 ***IP ADDRESS REMOVED** 254
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0 dhcp
access-list 1 permit 10.10.20.0 0.0.0.255
access-list 1 permit 10.10.30.0 0.0.0.255
access-list 1 permit 10.10.40.0 0.0.0.255
access-list 1 permit 10.10.60.0 0.0.0.255
access-list 1 permit 10.10.70.0 0.0.0.255
no ip nat inside source list 20 interface GigabitEthernet0/0 overload
no ip nat inside source list 30 interface GigabitEthernet0/0 overload
no ip nat inside source list 40 interface GigabitEthernet0/0 overload
no ip nat inside source list 60 interface GigabitEthernet0/0 overload
no ip nat inside source list 70 interface GigabitEthernet0/0 overload
no access-list 20 permit 10.10.20.0 0.0.0.255
no access-list 30 permit 10.10.30.0 0.0.0.255
no access-list 40 permit 10.10.40.0 0.0.0.255
no access-list 60 permit 10.10.60.0 0.0.0.255
no access-list 70 permit 10.10.70.0 0.0.0.255
Kind Regards
Paul
port-channel 1 is connected to a second 2960-s switch, non poe 24 port. I checked the CPU processes on that and it doesn't appear to be affected by my issue. The switch is for a few of my servers which have 4 nics each.
I will go a head and make the changes to the access ports per your suggestion.
Here's an update on my CPU usage after the changes I made. There appears to be no change. The following is my CPU usage with all 12 IP cameras plugged in. When I was using my pfsense box, I was getting a CPU usage of about 35%/0% on the 2960 switch.
CPU utilization for five seconds: 72%/26%; one minute: 64%; five minutes: 62%
4 734295 41669 17622 8.19% 1.28% 1.02% 0 Check heaps
44 18186 91523 198 0.09% 0.06% 0.04% 0 Net Background
80 30469 2422406 12 0.39% 0.19% 0.15% 0 Draught link sta
85 32745 675136 48 0.29% 0.13% 0.11% 0 RedEarth Tx Mana
86 49570 3191865 15 0.19% 0.28% 0.29% 0 RedEarth Rx Mana
104 57777 1815200 31 0.09% 0.25% 0.23% 0 HLFM address lea
122 46013 683077 67 0.59% 0.27% 0.20% 0 hpm main process
126 295725 72957 4053 0.79% 0.75% 0.74% 0 hpm counter proc
149 8126 354107 22 0.09% 0.07% 0.04% 0 Hulc Storm Contr
157 20016279 1818386 11007 29.29% 29.94% 29.63% 0 Hulc LED Process
168 160033 14563 10989 0.19% 0.21% 0.20% 0 HQM Stack Proces
169 45106 29106 1549 0.09% 0.06% 0.06% 0 HRPC qos request
185 346972 291106 1191 0.59% 0.41% 0.39% 0 Auth Manager
188 22391 25112 891 0.09% 0.04% 0.03% 0 CDP Protocol
214 140658 485451 289 0.19% 0.18% 0.16% 0 Spanning Tree
231 14908 728883 20 0.09% 0.13% 0.09% 0 UDLD
CPU utilization for five seconds: 29%/11%; one minute: 25%; five minutes: 23%
31 1087608 21196507 51 17.35% 14.42% 13.30% 0 ARP Input
68 252 33825 7 0.07% 0.13% 0.15% 0 Per-Second Jobs
86 468 135212 3 0.15% 0.17% 0.17% 0 Netclock Backgro
107 5856 67596 86 0.07% 0.04% 0.05% 0 BPSM stat Proces
111 20 4285594 0 0.15% 0.13% 0.14% 0 Ethernet Msec Ti
141 14000 161489 86 0.07% 0.03% 0.02% 0 IP Input
The output is not matching.  Post the complete output to the command "sh proc cpu sort | ex 0.00".
What happens if you take the cameras off?  Does Hulc LED Process go down?
And what firmware is the switch running on?
The switch is running the following: Cisco IOS Software, C2960S Software (C2960S-UNIVERSALK9-M), Version 15.0(2)SE11, RELEASE SOFTWARE (fc3)
I attached two CPU usage txt files. One with cams plugged in, the other without cams plugged in. Hulc LED goes down with no cameras.
Post the complete output to the command "sh interface <CAMERA PORTS>". Both of them.
Also post the interface config for the two camera ports.
Is LLDP enabled? (sh lldp)
I believe this is what you request:
Switch Port 1 (Camera 1):
MainSwitch#sh interface gigabitEthernet 1/0/1
GigabitEthernet1/0/1 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 64d8.1407.1a81 (bia 64d8.1407.1a81)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is 10/100/1000BaseTX
input flow-control is off, output flow-control is unsupported
Last input never, output 00:00:00, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 372000 bits/sec, 720 packets/sec
5 minute output rate 477000 bits/sec, 922 packets/sec
37607321 packets input, 30284564638 bytes, 0 no buffer
Received 17090621 broadcasts (17427 multicasts)
4727 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 17427 multicast, 241 pause input
41547378 packets output, 2686663166 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier, 0 pause output
MainSwitch#sh run interface gigabitEthernet 1/0/1
Current configuration : 145 bytes
end
Switch Port 3 (Camera 2):
MainSwitch#sh interface gigabitEthernet 1/0/3
GigabitEthernet1/0/3 is up, line protocol is up (connected)
Hardware is Gigabit Ethernet, address is 64d8.1407.1a83 (bia 64d8.1407.1a83)
Last input never, output 00:00:01, output hang never
5 minute input rate 165000 bits/sec, 314 packets/sec
5 minute output rate 332000 bits/sec, 642 packets/sec
7365639 packets input, 8009645057 bytes, 0 no buffer
Received 1825949 broadcasts (7742 multicasts)
329 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
0 watchdog, 7742 multicast, 13 pause input
18658983 packets output, 1218049634 bytes, 0 underruns
MainSwitch#sh run interface gigabitEthernet 1/0/3
end
MainSwitch#sh lldp
Global LLDP Information:
Status: ACTIVE
LLDP advertisements are sent every 30 seconds
LLDP hold time advertised is 120 seconds
LLDP interface reinitialisation delay is 2 seconds
