IP Forwarding, Port Forwarding and PAT
dangal.43
what are the differences between IP Forwarding, Port Forwarding and PAT?
please explain me technical and configuration difference for the same.
royalblues
Level 10
Level 10
IP forwarding
IP forwarding enables one workstation to sit on two LANs and to act as a gateway forwarding IP packets from one LAN to another. IP forwarding is also referred to as ?bridging? networks.
http://www.troubleshooters.com/linux/ip_fwd.htm
Port forwarding
Port forwarding allows remote computers (e.g. public machines on the Internet) to connect to a specific computer within a private LAN.
http://en.wikipedia.org/wiki/Port_forwarding
http://portforward.com/help/portforwarding.htm
PAT
Port Address Translation (PAT) is a feature of a network device that translates TCP or UDP communications made between a host and port on an outside network, and a host and port on an inside network. It allows a single IP address to be used for many internal hosts.
http://en.wikipedia.org/wiki/Port_address_translation
HTH, rate if it does
Narayan
